Go to Post An FRC team's success should not be measured in how many robots it can build or how many blue banners it can collect. It should be measured by how many engineers (and other professionals) it 'builds'. - jvriezen [more]
Unread 03-11-2010, 21:30
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
[FTC]: Deadbands (axis/motor power restrictions)
Hello fellow programmers!
I am currently working on finding a solution to a probable bug which in being a programmer for the last 2 years never occurred. The base joystick to motor control has a bug in it.
4wd
Code:
motor[motorD]=joystick.joy1_y1;
motor[motorE]=joystick.joy1_y2;
motor[motorF]=joystick.joy1_y2;
motor[motorG]=joystick.joy1_y1;
It preforms the funtion, but one wheel always continues to spin even when the joystick may only be giving a output of 1 or 2. How do you implement dead bands on your analog sticks to control the motor power output.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 04-11-2010, 12:56
RCXRM RCXRM is offline
FTC #0245
Rookie Year: 2007
RCXRM is an unknown quantity at this point
Re: [FTC]: Deadbands (axis/motor power restrictions)
Here is the code we've used to create deadbands:
Code:
if((joystick.joy1_y1 < 5) && (joystick.joy1_y1 > -5)) joystick.joy1_y1 = 0;
Unread 04-11-2010, 13:40
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
I dont have it right here, but ours is something like:
Code:
// since joysticks return -127 to 127 values, and since motors react in a
// rance of -100 to 100, this function adds a midpoint deadband and
// adjusts the speed to be within the expected range.
int deadband(int invalue)
   // if the value is between -27 and 27 then use
   // that as the deadband and return 0
   if (abs(invalue) < 27) return 0;
   // if the value is negative, add 27 to bring the (-27 to -127) to (0 to -100)
   if (invalue < 0) return invalue + 27;
   // if the value is not > 27 then it already exited, so - 27 and return
   return invalue - 27;
task main()
   motor[motorA] = deadband(joystick.joy1_y1);
   motor[motorB] = deadband(joystick.joy1_x1);
   motor[motorC] = deadband(joystick.joy1_y2);
   motor[motorD] = deadband(joystick.joy1_x2);
Unread 04-11-2010, 17:23
Code:
haha that looks exactly like what I am trying today thanks
I'll just see what works best I may end up going with the other idea too but thank you for your help.
John Fogarty
GForce 3864
John Fogarty
Unread 04-11-2010, 19:03
coollog's Avatar
coollog coollog is offline
Q
AKA: Qingyang Chen
FTC #5485 (PRO)
Rookie Year: 2007
coollog is an unknown quantity at this point
Another way to do it is
Code:
int threshold = 12;
motor[motorD] = (abs(joystick.joy1_y1) >= threshold) * joystick.joy1_y1;
This basically just zeroes any joystick value that is within a threshold of 0.
Will a 1/3 horse power sump pump motor burn up at half power? Weird Al/ Tony Motors 46 09-04-2010 21:11
Axis Camera Power polarity hurtzmyhead Electrical 4 03-02-2010 09:21
Axis 206 Camera Power Supply EricWilliams FRC Control System 1 02-02-2010 17:18
Axis Camera 206 Power Connection Matt2081 Electrical 7 24-01-2010 15:51
axis camera power cable falling out.. dani190 Electrical 7 19-02-2009 13:55
