Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 15-10-2001, 12:15
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Exclamation Drill Motor Gearbox Problems...
Our team has been having some problems with one of our drill motor gearboxes. The problem was that one of the clutches was slipping quite easily even though it was set to the highest setting. We disassembled the clutch mechanism to discover some missing parts. Luckily we had these parts on hand from spare FIRST gearboxes.
It occurred to me that this may not be an isolated incident. I just want to be sure no other teams are having this same problem. We discovered our problem when one of our gearboxes exhibited a clicking noise while under modest loads.
Upon disassembly we found the steel plate that resides between the clutch balls and the clutch spring was missing along with the plastic part that holds the index spring in place. When we got this gearbox we also notices that one of the two screws that holds the whole clutch together was missing.
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
More drill motor problems, jeeze. blindguy Motors 4 12-02-2003 09:06
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
