Go to Post a determined team can accomplish miracles. - Wayne C. [more]
Unread 06-11-2010, 12:34
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
[FTC]: Early robot Testing
http://www.youtube.com/watch?v=p-Ns6LId2GU
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 06-11-2010, 18:11
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: [FTC]: Early robot Testing
I call shenanigans :-)
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 07-11-2010, 18:49
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
That looks a bit off...is that real?
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 07-11-2010, 20:46
ssi ssi is offline
AKA: David Spangler
FTC #2843 (Under the Son)
ssi will become famous soon enough
From what I remember of last years robot, they had a very accurate and consistent shooting mechanism. They might have been able to pull this off. Also, their shooter design, using a spring loaded arm, could probably be modified to do this. The one problem I see is that it looks like it might be violating the rules for a maximum shot of 10 feet horizontal and 4 feet vertical.
Unread 07-11-2010, 22:45
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
The trajectory of the batons are off and tend to defy the 2 basic laws of projectile motion: 1. Constant y-axis acceleration and 2. Constant x-axis velocity(yes i'm ignoring air resistance...).
This is why a called shenanigans
Unread 07-11-2010, 22:56
i conquer...that third one looked like it a invisible air roof before coming back down. SHANANGANS
John Fogarty
Unread 07-11-2010, 23:34
dcribbs dcribbs is offline
AKA: Dave Cribbs
FTC #5598 (Parish Robotics)
Team Role: Coach
dcribbs has a spectacular aura aboutdcribbs has a spectacular aura about
Very interesting video!
I have kind of a random question that was brought to mind by watching your video..
Our team built a practice field using FIRST's low cost field perimeter plans and have found it to be too weak to use effectively. It is quite easy for a robot to push against the wall and move/bend it more than the competiton field. We were planning on just framing up some plywood to the correct dimensions to make a sturdier practice field. I noticed your team did the same in the video. We don't want to over-do it and have the field be to heavy to transport for demos and the like, but we also don't want to go to light and run into the same problem as before.
What thickness plywood did you use?
What dimension lumber did you use to frame?
Do you like your field, is it sturdy enough?
Any advice or pointers that you could give would be greatly appreciated!
Thanks.
Dave Cribbs
Coach & Teacher
FTC - Team 5598, 6635, 6795
FRC - Team 3626
Unread 08-11-2010, 08:30
ssi ssi is offline
AKA: David Spangler
I don't know, that G-Force team is pretty sharp. They could probably rewrite those pesky laws of physics. Personally, I think all teams need to spend all of their time trying to copy this design
As for the field wall question. I don't know about 2818, but we built up a low cost field wall framed up with 1x4s and covered with hardboard. It works reasonably well and isn't too heavy. The worst problem we ran into was getting the corners to stay together. As for flex, I have seen some competition fields with a lot of flex in the sides (more than there should be). Our design flexes, but it is not too bad.
Unread 09-11-2010, 14:31
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Exclamation Re: [FTC]: Early robot Testing
How many of you looked at this video after viewing the baton launcher video? Anybody know who this team is and where they are located. FTC 72 Garagebots I'd like to know what future iterations look like for this drive-train.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 09-11-2010, 17:52
robodude03's Avatar
robodude03 robodude03 is offline
AKA: Rene Haro
FRC #1538 (The Holy Cows)
Team Role: Tactician
robodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond repute
Hello Andrew,
I am a mentor for this team and we have been working hard on delivering a new video of our updated drive train. It took several iterations to figure out the correct wheel spacing to make it over the mountain, but it now goes over. Currently we have pulled off the electronics to work on our arm/manipulator for the batons. Please feel free to subscribe to my channel on youtube. We hope to have a new video posted soon.
FTC 72 - Garagebots
Lancaster, CA
Team 1538 - The Holy Cows
2015 Championships - Quality Award sponsored by Motorola
2014 Championships - Media and Technology Innovation Award
2013 Championships - Chairmain's Award Winner and Newton Finalists w/ 217 & 1986
2013 to Present - 1538 Mentor (Digital Media/Strategy)
2004 to 2012 - 399 Mentor/Coach
2000 to 2004 - 399 Driver
Unread 10-11-2010, 20:24
team F.T.C 4240's Avatar
team F.T.C 4240 team F.T.C 4240 is offline
Two cookies, one robot, all awesome
AKA: Derrick Maust
FTC #4240 (Techno Clovers)
Team Role: Driver
team F.T.C 4240 has a spectacular aura aboutteam F.T.C 4240 has a spectacular aura about
Well let me clear everything up for you, first it is fake!
Kendrick made the batons in blender it took only 15 minuets to make also if you look closeup you can see that the first baton looks good then the 2nd spins slower and moves slower the 3rd spins the other way and the robot doesn't move along with other things, I just wanted to point that out, he made it the first week the game came out and he didn't have very much time to work on it so he posted it anyways. But it was a cool video
"Like" us on Facebook to get info and updates on the team: http://www.facebook.com/FTCTechnoClovers
2008-09: MD Finalist Alliance Captain, MD Inspire Award Winner, Worlds Division Finalist.
2009-10: MD Winning Alliance Captain, MD Think Award Winner, OH Winning Alliance Captain.
2010-11: MD Finalist Alliance Captain, MD Innovate Award Winner, DE Winning Alliance Captain, Worlds Edison Division Finalist Alliance Captain.
2011-2012: MD Annapolis Qualifier Winning Alliance, PTC Design Winner.
DE State Inspire Award Winner.
MD State Winning Alliance Captain, PTC Design Winner.
World Championship Franklin Winning Alliance, Thanks Landroids and Cougar Robotics!
[FTC]: Increase Program Testing Speed? ethan_orion FIRST Tech Challenge 1 31-10-2010 20:41
[FTC]: Tether Testing jaster67 FIRST Tech Challenge 1 08-10-2010 00:26
Testing Controller Without Robot? Darth Pbal National Instruments LabVIEW and Data Acquisition 2 07-02-2010 21:56
Testing Robot Controller haywirerobotics Control System 0 23-01-2006 21:32
