CAN - reading current values
Hi all,
Question regarding black jags with CAN; Without using current control mode, (want to stick with voltage control), can we still access information about the current going through each of our jags, and display them on the dashboard? Also, in regard to the 'Jaguar Communication Cables' section in MDL-BDC24_GSG.pdf (from luminary micro's jaguar page): -can the mentioned (6wire) A2662R-07-ND be used (without modification) between the jags, and between the crio and jag? -are the steps (at the bottom of page 30) to be done to the modular RJ12-DB-9 abapter AND for the terminator plug (both with 100ohm resitors)? thanks. Last edited by pfosx : 07-11-2010 at 20:13. |
| paper: CAN Jaguar Speed Control with Current Limit | Ether | Extra Discussion | 3 | 22-08-2010 00:59 |
| Help Reading Joystick button Values | PlaidPillagers | NI LabVIEW | 1 | 11-02-2010 11:27 |
| Reading Robot values during a match | jmanela | NI LabVIEW | 2 | 07-03-2009 19:58 |
| Reading Joystick Values Help | FearlessLeader | C/C++ | 5 | 17-01-2009 23:33 |
| Split topic - How many channels can the current (2004) Oi's and Rc's Handle? | Elgin Clock | Control System | 6 | 02-01-2005 14:02 |
