Go to Post What are you people going to rumor mill about if we ever actually get a water game? - Kevin Sevcik [more]
Unread 11-10-2010, 03:47 PM
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
FRC Netbeans Template
My netbeans which is 6.7.1 does not allow me to download the FRC templates. I put the website in plugins, but my update tab doesnt open so i cant download anything. I tried to download it manually via http://first.wpi.edu/FRC/java/netbeans/update/ but I dont really see any .nbm files to download. So would there be any other way to download and install the templates.
Unread 11-10-2010, 04:20 PM
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: FRC Netbeans Template
I see several .nbm files at the link you provided (five of them in fact).
To automatically install from within NetBeans, however, you want to go to the Settings tab - NOT the Updates tab. Add the given URL as a new provider, then go to Available Plugins to download the SDK. Once you already have it installed, the Updates tab will allow you to download any updates to the FRC stuff, if they are available.
If the above directions still don't work for you, make sure that NetBeans knows about any proxies/etc. that are keeping it from seeing the WPIlib site.
Unread 11-10-2010, 06:08 PM
FRC #0640
oh, ty, but to do it manually i just download which files?? I'm not really familiar with .nmb files. So exactly what files would i have to download and after i download "said" files, i just extract and put in to netbeans?
Unread 11-11-2010, 08:54 AM
You can go into the "Downloaded" tab of the Plugins menu, and press "Add Plugins...". Navigate to each of the .nbm files, and press "Open".
Unread 11-11-2010, 09:36 AM
FRC #0640
ok i understand that part, but im not that quite sure which files to download exactly. Do i just download the update.xml files, edu-wpi-first files or something else??
Unread 11-11-2010, 09:46 AM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
This is covered in the Getting started with Java in the section "Installing Sun SPOT Java SDK for FRC without Internet Access"
Unread 11-11-2010, 12:01 PM
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
This document might help you also:
http://kellrobotics.org/files/Instal...ns_For_FRC.pdf
Ed Barker
Unread 11-15-2010, 09:57 AM
FRC #0640
thanks guys i figured it out, got the plugin downloaded and install
NetBeans Debugging wrepavich Java 1 02-09-2010 07:14 AM
Netbeans help please darkorbit Java 1 01-18-2010 09:36 PM
Program C++ in NetBeans? camper365 Programming 7 01-17-2010 10:12 PM
2008 MPLab FRC Template Andrew Bates Programming 1 12-08-2009 07:16 PM
LabVIEW FRC Template koreabell NI LabVIEW 2 11-16-2008 08:46 PM
