Add Code to the Robot main .vi
I am from Team 3270 and i am a new programmer for the team. I wanted to know how to add code I made and put it into the robot main.vi so that i would be able to execute it. I tried to execute the code by itself in the developer station but nothing will happen and when i tried to add it through copy and pasting it, it did not work.
Please Reply ASAP with a solution thank you |
Re: Add Code to the Robot main .vi
This reminds me of the year someone posted that they were missing the assembly manual in the KOP! If you are just beginning to use Labview, I would suggest you go to www.frcmastery.com where you will see some great examples that will answer your questions. I would further suggest that you start by using the examples provided. You can program a fully functional drivable robot with just those examples. Then, you can start using the template. I hope this helps. |
| Camera Code in main thread + watchdog = twitching servo? | Joohoo | Java | 1 | 22-02-2010 16:26 |
| Passing the main robot frame with the kicker. | cilginbilgin | General Forum | 5 | 13-02-2010 06:35 |
| Passing the main robot frame with the kicker. | cilginbilgin | Rules/Strategy | 3 | 12-02-2010 07:21 |
| 2009 blinking code for main light | mac | General Forum | 2 | 29-01-2010 21:43 |
| the main code | Roni2230 | Programming | 9 | 10-01-2008 12:14 |
