Go to Post We are just here to give back to a program that gave us so much as students. - Alex Cormier [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 16-11-2010, 21:47
Coach Doug Coach Doug is offline
FTC #3529
Coach Doug is an unknown quantity at this point
[FTC]: (FTC) Doubling motors on a controller
The team is trying to determine how to wire our 8 motors with only using 3 controllers. We have a 4 motor tank drive set up so we are considering wiring up one side of 2 motors as motor 1 and the other bank of 2 motors as motor 2 on the controller.
Question: By wiring it this way - will each motor on a given side be provided the optimum power or did it get cut in half?
2nd question: Should we double the wires up to each pos/neg post on the controller or run the positive to the first motor, hook that motor negative to the positive of the 2nd motor, then 2nd motor neg to neg side of controller?
Appreciate some input please.
[FTC]: FTC weight and number of drive motors Frank Neuperger FIRST Tech Challenge 4 14-09-2010 08:54
[FTC]: Bluetooth Problem with LabView/FTC Controller Station James Dowd FIRST Tech Challenge 8 27-10-2009 10:40
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
