Go to Post Dean's said it before, and it's been repeated many times, but it clearly hasn't sunk in yet, so I'll say really loudly. FIRST is not a science fair! - Karthik [more]
Unread 19-11-2010, 15:38
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Current Sensors
for a project I'm working on I need three different, ideally very cheap, current sensors.
One from 0-30 Amp, one from 0-75, and one from 0-150.
I can't use a jaguar due to size and cost. I've heard of teams using ~$10 sensors for this before, but wouldn't know where to find them or what brands work well. I did a bit of googling and found these, which cover the range nicely and are in stock at a few places.
Unread 19-11-2010, 16:08
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Current Sensors
I spent a lot of time looking for current sensors in this range while designing the PI (the PD's predecessor). You'll be hard pressed to find an easier solution than Allegro's hall effect based sensors (e.g ACS758) . I really like their funky-space-ship looking ones, as they combine low resistance, isolation, and buffering into one odd looking package. The accuracy is decent, but not best-in-class. If you are making less than a hundred of whatever device you are designing, grab the appropriate Allegro sensor and be done with it.
If you are making more, I'll need more information on what your requirements are.
Your other options are
* Some other hall sensor
* Current sense resistor
* Current sens transformer (for AC current only)
* Some magnetoresistive sensor (yuck).
"Some other hall sensor" will be mostly a test of your google-fu.
"Current Sense Resistor" takes a bit more thought than a hall sensor, because it isn't isolated. This means that you need to be careful about protecting your delicate circuitry from your 100 amp path. It isn't difficult, it is just time consuming.
EDIT / PS:
If you go with the allegros, bear in mind that they are ratiometric. If at all possible, sample them with a ratiometric ADC. Otherwise, your power supply noise is going to wind up in your measurement.
PPS: What sort of accuracy do you need?
Unread 19-11-2010, 16:43
AdamHeard's Avatar
Lead Mentor
Re: Current Sensors
They'll be hooked up to a vex controller,
+/- .5 amps for the 30 would be good, +/-1 for the rest is probably good as well.
Unread 19-11-2010, 17:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Current Sensors
Adam,
When we did Stangesense a number of years ago we used a Maxim Chip. The resistor needed was a .001 ohm which is perfect as it is 1 foot of #10 wire. We added it in the negative power lead of the Victor but you can really put it anywhere. If you search on CD you will find the circuits and chips.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 19-11-2010, 18:16
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Current Sensors
One possible solution on a board ready to go.http://www.pololu.com/catalog/product/1187
Unread 19-11-2010, 18:19
AdamHeard's Avatar
Lead Mentor
Re: Current Sensors
I do like that!
I am not completely opposed to making a circuit, but I would prefer something already mounted and good to go (attaching wire leads is fine).
Current Sensors maclaren Electrical 15 04-12-2007 15:21
Current sensors wiring zainali Electrical 5 13-02-2004 00:39
Current sensors use?? zainali Motors 1 09-02-2004 19:04
Current draw sensors capacitors? zainali Technical Discussion 1 08-02-2004 14:35
current draw sensors zainali Technical Discussion 2 08-02-2004 11:40
