Learning Java
Hi everyone.
I really want to learn how to program using java. Does anyone know what is the best way for me to learn the language? Thanks. Sincerely, Austin Bianchini |
Re: Learning Java
There isn't really a best way. You have to self-explore with guidance from tutorials, guides, books, or mentors.
There is a Getting Started guide for specifically programming for the robot available on this page http://first.wpi.edu/FRC/frcjava.html There are plenty of resources available to help you and there's always places and people to ask questions if you get stuck. |
Re: Learning Java
If you're familiar with another OOP language (C++, Python, even parts of PHP), then you're already halfway there. If this is the case, then you simply need to learn the syntax, nagging rules and guidelines, etc. I recommend through the Getting Started guide that ZonChau mentioned. While it's not a "beginner's guide" to Java, it does introduce you to programming the robot in Java. How to include classes, how to use some basic functions, etc. The rest, I pretty much learned from just Googling.
Re: Learning Java
There is an online (and downloadable) Java SE tutorial that is a good place to start learning Java. Java SE = "Standard Edition", which is the version of java designed for desktops and servers. Since Java for FRC is based on the ME ("Micro-edition"), there are some parts of the tutorial you can skip over:
Starting from http://download.oracle.com/javase/tutorial/ there are several "trails" to follow:
You can find the full API documentation (javadoc) for Java ME, WPILibJ, and the Squawk JVM in the Java for FRC SDk once you install it, in sunspotfrcsdk/doc/javadoc/index.html. You can also see the Java ME API set online at http://download.oracle.com/javame/co...139/index.html. |
| Learning to Program in Java | Kingofl337 | Java | 15 | 10-10-2009 10:47 AM |
| **FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** | Pjohn1959 | Programming | 37 | 08-31-2009 03:55 PM |
| Learning C | idogis1 | Programming | 2 | 01-07-2008 07:56 PM |
| Robocode: Learning JAVA the fun way. While fighting with robots. | Denalin Fusion | Chit-Chat | 2 | 09-26-2005 11:22 PM |
| learning | Tyler Olds | 3D Animation and Competition | 3 | 05-07-2002 10:55 PM |
