Go to Post Holy Orbit ball Batman!!!!!!!!!!:yikes: - yodameister [more]
Unread 11-22-2010, 06:05 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Working with WRS C++ Workbench Presentation
Greetings Fellow C++ Users!
Attached you will find a copy of the presentation that Greg Smith & I gave at the Virginia Region Workshop at VCU on 11/20/10. This presentation provides some of the reasons you should/should not use C++ for your teams and then walks you through the process of creating a C++ project, compiling it, downloading it and debugging it on the cRIO. The presentation also includes a few links to information of interest to C++-oriented teams. It's got a lot of screen shots, so be patient in the download if you've got a slow link.
Enjoy,
Mike
Unread 01-13-2011, 12:45 AM
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Re: Working with WRS C++ Workbench Presentation
This is awesome! Thanks! This will definitly save me a lot of time relearing the target connection stuff!
Unread 01-14-2011, 09:52 AM
DtD's Avatar
DtD DtD is offline
AKA: Pathogen David
You might want to add that you need to change the Kernel image to C:\Windriver\WPIlib\vxWorks otherwise you get no connection and cryptic errors.
Unread 01-14-2011, 02:01 PM
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
Ah yes! The image for the WRS target server. Quite right. I'll add that to the presentation.
Thanks!
Mike
Workbench with SVN problems M.Rehberg C/C++ 3 01-18-2010 11:35 AM
Teams happy with Wind River Workbench? gvarndell C/C++ 59 07-28-2009 09:13 PM
If you're having trouble with Workbench gvarndell C/C++ 2 01-31-2009 11:30 AM
Workbench is not working. Need help Please electrowave89 Technical Discussion 5 01-19-2009 10:58 AM
Problem with Woodie's Presentation tony.dalia.195 General Forum 12 01-05-2008 08:34 PM
