Go to Post Everyone is wrong! - Chris is me [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 23-11-2010, 20:28
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
how to set up an alternative netbook
Hi, I been looking through the posts, using search but I do not understand how to use a netbook as a backup.
Here is what I have done so far:
In the netbook, which uses NTFS format, I set up a partition drive for the FIRST usb image with about 4.88 gb of memory under FAT32, using the included Disk Management in Windows 7 Starter software (on the Gateway Netbook LT20).
I have tried to boot up using the USB Image but it is not being recognized, I went in to check the memory of the USB Image on the netbook and it states the drive is empty. I will try it on another computer to set up the imagine. Anyway, my question is two fold:
1) Did I do the right steps to create another drive that can run the FIRST software
2) How do I get the netbook to install the software from the flashdrive onto extra drive I created.
Thanking you.
how to set up the gyro? bfighter Technical Discussion 6 13-02-2010 13:50
how to set up 206 axis cam in labview team3323 Programming 3 02-02-2010 17:02
how to set up 206 axis cam in labview team3323 General Forum 0 02-02-2010 15:23
How to set the deadband in motor vi RickErmer NI LabVIEW 1 16-02-2009 20:07
How to set up and run a FF League properly. Alex Cormier Fantasy FIRST 4 27-02-2006 17:18
