Go to Post I think we need to take away your hammer privileges. - Katy [more]
Unread 02-12-2010, 00:58
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
CIM Quiz 2
The following was inspired by a recent discussion I had about analyzing a vacuum ball magnet:
The power required to drive a certain vacuum impeller is given by the equation
watts = (rpm^2)/81500
The impeller is being driven by two motors: a CIM and an FP, each through a separate gearbox.
The motors are each being driven at 12 volts.
Find the theoretical gear ratios of the two gearboxes which produce the fastest impeller speed.
[edit 11:56am] Note: for purposes of this analysis, ignore gearbox losses. [/edit]
[edit 4:54pm] Note: For this hypothetical problem, ignore the 40amp breaker and allow each motor to draw whatever current it needs (with 12V applied) in order to maximize the impeller speed. Pretend the impeller is only operated momentarily. [/edit]
CIM quiz Ether Motors 20 21-11-2010 19:13
Safety Quiz? morg102 Games/Trivia 1 20-01-2009 13:23
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Gundam Quiz GAT-X105 STRIKE Games/Trivia 3 09-02-2005 17:11
Team Quiz MrsT General Forum 7 02-03-2002 18:54
