Go to Post One of those things I learned in kindergarten - never introduce myself to an “enraged” woman wielding a clipboard. - Mark McLeod [more]
Unread 03-12-2010, 17:10
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
How do you build telescopes/forklifts?
Hi CD,
I've been involved with FIRST since 2005, but never been involved in building any kind of telescoping arm or forklift device.
I got to thinking about it and couldn't think about simple ideas on how to solve the main problems:
what slides past what? for telescoping I would think it would be a square tube within a square tube with some wheels or rollers to allow movement. But most forklifts use two sets of tubes to improve rigidity so how do you link them and allow them to slide?
I can't imagine drawer slides are used extensively since they weigh so much.
regarding opening the telescopes and lifts: I'm guessing the cable+drum+pulleys system is the standard but with the telescoping arms some things just don't add up regarding the way the cables need to wrap.
I would appreciate some explanations and also pics of said systems would be very much appreciated. I couldn't find any closeups.
I know FRC233 (Pink) is very strong with telescopes. any other teams to look out for?
Thanks for your help in educating myself and hopefully others!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 03-12-2010, 17:19
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: How do you build telescopes/forklifts?
It's been a while since 330 did one of their blue lifts...but the last time one of those broke, it was self-inflicted and it merely bent.
Lifts do not have to have their extending sections inside each other. In fact, it's a lot easier to do a cable-powered lift if they are not inside each other.
I'll mention cabling routes here...
There are 2 types: continuous and cascading. See this thread for explanation. (post #3) If cabling is used, it is best to ensure that there is a "gravity" cable to make sure that your lift can retract.
There are, of course, other means of telescoping.
If a 2-tube-set lift has the sections outside of each other, each "level" has a partner joined to it in the other set. Joints are typically at the bottom and on one side.
You might want to take a look at 25's section in the 2007 Behind the Design book, as well. There is another robot in there as well--19??--that had a telescoping arm, IIRC, but it was an internal-section one. Oh, and don't forget to look at 357 in the same book...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 03-12-2010, 17:20
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Originally Posted by Leav View Post
Hi CD,
-Leav
254/968 had a solid lift design as well.
There is a manipulator presentation from 330 (and I've seen others as well with this information) that outlines the more common ways of routing cable/chain for the lifting motion.
173 had a very unique design in 05, I think they reused it in 07 as well.
Unread 03-12-2010, 18:39
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
On the cascading rig, how do you determine the diameter of the two pulleys. My guess was that it is determined by the ratio of lengths between the lifting cable and retracting cable, can someone confirm this?
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 03-12-2010, 18:47
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
The diameter of the pulleys in a pulley system have absolutely no effect on the reduction of that system. Also, you do NOT want to use drawer slides. They have to much friction, don't extend far enough, and aren't nearly strong enough. I'll have a couple cad sketches up of systems of bearings and cascades in a bit (once I get done with a work issue..)
Edited to add:
That's a picture of the 254/968 setup from a while back (the blue tube in the picture below). It works well if you want only 1 stage. If you want multiple stages (per the PDF) you can make rectangular frames, then use C-channel with some bearings in them at the tops and bottoms of each frame to guide them.
In '08 we used IGUS slides to do it. It worked remarkably well, however the slides were certainly not meant for that application and we had to do pretty regular maintenance on them. Video of that robot here:
http://www.youtube.com/watch?v=jOJmiPAcZt4
In addition, many hi-lo setups have counterweights to counteract the weight of each stage. That year, we used bungie cord and pulleys so that each stage effectly weighed "nothing" - in fact the motor had to keep the stages down because we decided to also counteract some of the weight of the ball.
Unread 03-12-2010, 18:48
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
AM has a lot of good info on their manipulators powerpoint presentation here. It explains some of the math behind the designs which is good as well
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 03-12-2010, 19:43
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
One thing my old team used to do a lot was build telescoping sections by interfacing 8020 with a delrin slider (you can see the result relatively well here). Overall, it was simple to implement and mounting pulleys was easy.
If someone optimized the weight, and figured out how to reduce binding more, this design could work pretty efficiently.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 03-12-2010, 19:53
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Others have addressed cable/chain routing so I will not. Besides when my team did it we used something close to 22 ft of chain for an 8 ft lift. (Not at all efficient routing.)
What I will bring to the discussion is full extension draw slides. They are on the heavy side but made for extending. Nothing to build, just drill holes and mount. What they cost in weight is made up for in simplicity, availability of spares and speed of assembly. Think about side loads and getting hit with them up when looking at load ratings.
Also think about how you will determine full extension or retraction. Our system had a shuttle that ran up and down a tract on the top stage and two sets of draw slides on aluminum tubing to get to 8 feet. With binding, any stage could move or stick during the lift. We counted stripes on the drive axle to determine amount of motion. This was great accept we could not get the controller to remember the position between restarts. This was solved with a home switch in the lowest possible position for the upper stage of the lift.
Unread 03-12-2010, 21:46
Tom Line's Avatar
Rookie Year: 1999
That sounds very similar to what we considered. We could have used an encoder in the toughbox (relative) with a home switch at the bottom of travel, however we opted for a 10-turn potentiometer riding on the bottom chain so that we had an absolute value and could minimize wiring.
Unread 03-12-2010, 22:07
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
Whenever our team has made elevators, we have used 80/20 like material and delirin sliders as well. It's generally very east to set up albeit a little on the heavy side.
Unread 04-12-2010, 01:31
Does anyone have detailed pictures of Hammond from '07? That is probably one of the best examples I can think of, but I can't seem to find any close up pictures of their elevator on here or their website.
Mike Schreiber
Unread 05-12-2010, 11:30
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
Hi CD,
-Leav
we did this in '08 with 80/20 and some sort of sliders, using pulleys and rope to lift it
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 05-12-2010, 12:19
lbarger's Avatar
AKA: Lee Barger
We've tried the 80/20 extrusion and Delrin sliders as well, but did not like the binding. That is why we went with draw slides.
With the extrusion/slider set up you typically need two sliders on each 'post' for stability. To minimize binding you want to keep the sliders as far apart as possible. This usually means mounting one slider at the top of the lower lift member and the bottom of the higher lift member. As the lift is extended, the slider on the upper member moves with it and gets closer to the the slider mounted on the lower member. Some experimentation can determine just how close the two sliders can approach without bind. You can then put in stops.
A general rule of thumb is bearing surfaces should be separated (lengthwise) about 3 times their diameter (or width). My experience suggests this may be a little close for 80/20 hardware so you may need 4 or 6 times the width. (For a 1" extrusion this means 4 to 6 inches between the slider pairs.)
One last though on bind: Aluminum is actually have fairly 'sticky' material. Can you substitute another material or cover the aluminum (plating, enamel, powder coat)? Dry lube sprays may also help.
Unread 05-12-2010, 12:40
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: How do you build telescopes/forklifts?
Just to add to some of the suggestions on multi-stage lifts, Team175 (Buzzrobotics) has used aluminum square tubing, aluminum round tubing, as well as PVC for the stages. Provide enough clearance for Delrin bearings on the aluminum so there is no metal-to-metal contact between stages, and also reduces friction between stages. Instead of using metal cable, we use Spectra braided Cord (1/8" - 1050 lb tensile strength) Which has lighter weight, and allows for much smaller pulley radii, saving weight and space. In addition, we used a double drum-one side to wind up cord for lift, and the second to wind down for retraction of the lift, driven off the same motor. We install an encoder or a multi-turn pot to control lift movement, and put tensioning rubber bands on the cable ends to provide some extra length that is needed due to cord overlap differences on the drums. This also keeps tension on the cord so they won't come off the pulleys. Good Luck prototyping cable routing.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
  #15   Spotlight this post!
Unread 05-12-2010, 17:37
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Leav,
We have used manufactured slides in the past. I think our Triple Play robot used slides from McMaster. In other years we have manufactured our own using sheet aluminum bent to nest and telescope. Almost exclusively we use Spectra cable I think from McMaster. It is pretty amazing stuff as far as strength vs. size. We manufacture cable reels using delrin and string them through each section of lift from top to bottom of each section. As the reel pulls on the cable it becomes shorter raising the sections. If you design for two sides to lift, I recommend using a dual reel so that the cables are drawn at the same speed and distance. We have generally used FP motors or window motors in the lifts in the past.
Al
WB9UVJ
www.wildstang.org
________________________
How many of you build your own field? Jessica Boucher General Forum 43 07-03-2006 21:15
[ECDU]: How involved in the build are you? Steve Howland FIRST-related Organizations 7 08-03-2005 12:12
How long did it take for you to build your drivetrain? NoodleKnight Technical Discussion 18 29-12-2004 16:13
How many of you build computers? Alphawolf829 Chit-Chat 8 15-01-2003 16:19
how do you build a robot? archiver 2001 1 24-06-2002 01:59
