Go to Post The secret to this whole thing is that it's the robot that builds the team. - JohnBoucher [more]
Unread 03-12-2010, 19:35
greendog99's Avatar
greendog99 greendog99 is offline
FRC #0388 (Maximum OZ)
greendog99 is on a distinguished road
Exclamation [FTC]: Location of Samostat NXT file download
Does anyone know the location of the download files for SAMOSTAT for the NXT
Ready to take on the next challenge!
Unread 03-12-2010, 22:44
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: [FTC]: Location of Samostat NXT file download
It should be located at
C:\Program Files\Samantha Field Control System\.....
and then either in the labview or robotc folder depending on whether or not you are using robotc or labview to program your robot. You get it when you install the samantha fcs on your computer. The FCS can be downloaded from here if you do not already have it.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
[FTC]: NXT bluetooth connectivity issue Team 288 FIRST Tech Challenge 3 26-11-2009 12:38
[FTC]: NXT Brick Issues mincus38 FIRST Tech Challenge 4 12-11-2009 03:03
[FTC]: NXT-G programming ivybotter FIRST Tech Challenge 4 10-10-2009 12:02
[FTC]: NXT Display Code gdo FIRST Tech Challenge 6 05-02-2009 10:16
[FTC]: Bluetooth/NXT issues jbbjjbt FIRST Tech Challenge 5 23-10-2008 16:56
