Go to Post One of the Minbot inspectors at LA asked me how much a switch had to weight before it stopped being a "light" switch and started being a "heavy" switch. - ChrisH [more]
Unread 03-12-2010, 22:05
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Breakaway question: getting on platform with meccanum?
Were there any teams who got on the platform from Breakaway using meccanum? Let me explain: driving on the bump and balancing in the middle, then driving the meccanum wheels sideways, i.e. strafing, along the bump and on to the platform. If not, did any of your teams think of it during the design process?
I'm just curious to know because I thought of it a second ago. It would solve the problem of trying to turn sideways on the bump to be able to drive forward on to the platform. But would meccanum wheels even work here? Is the platform too high up? If you had really thick meccanum wheels I think they would make the jump, just like those infamous meccanum fork lifts that can go up stairs (though the manufacturer doesn't recommend it )
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 03-12-2010, 22:13
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Breakaway question: getting on platform with meccanum?
If I recall, the platform was a good 6 inches from the top of the platform. Mecanum wheels are poor climbers in the sideways direction to begin with, a lip almost their diameter would be impossible.
I believe some teams with swerve drive had success in this endeavor, however.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 03-12-2010, 22:16
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
You'd be effectively trying to climb a 6+ inch platform with two tiny crooked 1 inch "wheels". It's definitely far from doable.
Unread 03-12-2010, 22:17
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
To get onto the platform from the bump, assuming standard-sized mecanum wheels, you'd need to turn on top of the bump--there just isn't enough vertical clearance while going sideways to clear that lip. You could do it, but you'd need rather large mecanums.
For a wheeled vehicle, the approximate maximum size of vertical step it can go up is governed by the axle height. If you try to go up anything higher than the axle, you'll need either a really good coefficient of friction or an intermediate step of some form--an angle on your vehicle works as well. But a mecanum has at least 2 axle heights. One applies going forwards and backwards, one applies when going parallel to a roller--and then there's the one that comes into play when the end of a roller hits a wall. This one is the lowest one, and on your typical FRC mecanum isn't more than about half an inch off the floor. That's the maximum sideways vertical height it can climb without a ramp. Front-back, it's more like 3-4 inches, barely within range to get a robot onto the platform from the bump.
So, you couldn't strafe onto the platform; you'd have to go up like a 4WD--go up, spin, climb on. Now, with a bigger mecanum wheel, you might be able to do it.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 03-12-2010, 23:07
RoboMaster's Avatar
Hmm, yes 6 inches is a bit high.
Are there any Meccanum wheels available to FRC teams that would be big enough to possibly make this work? I think the biggest AM sells is 8 inch right? But of course you'd need something like 12 inch wheels...
Unread 03-12-2010, 23:12
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
I think it's BYOMW (Build Your Own Mecanum Wheels) for that challenge. 2826 might be able to do it--they built an offseason robot last year with massive ones. Even that one would have trouble strafing onto the platform, though--for a (best-guess) 14-inch diameter wheel, the roller tips still look to be about 1/2 inch off the ground.
Past teams:
Unread 04-12-2010, 17:12
RoboMaster's Avatar
I think you're looking at differently than me. I mean that not only do the maccanum wheels allow you to strafe on the bump, but the rollers would stick out enough that they would catch on the lip of the platform, pull the robot up as they turn, and continue to strafe on the platform. The rollers that are about at the level of the axle would grip on the platform.
Now that I think about it, that might not really work. The catching rollers would have to stick out farther than the others to be the only ones that catch on the lip of the platform. However, it still might work since all the rollers are angled.
Unread 04-12-2010, 17:26
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Which is exactly why it probably wouldn't work. If you were at an angle (and mecanums can move at 45* if they're programmed right), you might be able to get up if the rollers could lock relative to the wheel.
Angle of the rollers won't help if you're going straight sideways. Let's say that they did catch, though, just for the sake of argument. If the platform had a lip (it doesn't), up-going rollers could catch as well as down-going rollers. Bam, you're going nowhere at best, and going onto your top at worst (one wheel locks up solidly). Same argument applies for a flat surface that gets hit broadside by a mecanum--down+up=nothing doing.
The fact that they're rollers doesn't help you much, either; they roll. CG is off the platform, so they'll want to roll off of said platform unless they're locked--at which point you get into either lousy strafing ability or lots of mechanical complexity to lock when you want to climb.
Past teams:
Unread 04-12-2010, 17:33
AKA: Pinecone
Another thing to consider is that the torque of lifting most of the robot's weight off of the tip of the wheels is pretty large - your drivetrain might not be geared to provide that much torque.
Unread 04-12-2010, 18:11
RoboMaster's Avatar
Yeah, I see now how it really wouldn't work. Hmmm, well it was an interesting thought.
What I meant by the lip was just the edge/top/corner. Because it's a right angle, as apposed to, say, a vertical plane, it's something that a hook or catch can sort of grab on to. Think of a foot or large omni wheels grabbing onto the edge of the platform by their rollers.
Unread 05-12-2010, 11:24
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
you could put a secondary drivetrain that is perpendicular to, and slightly above the mechanums, powered by FP motors, using traction wheels for this sole purpose
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
A late question about Breakaway matches sithmonkey13 General Forum 4 03-12-2010 22:48
pic: Breakaway Field Mockup (now with a simulator!) 1986titans Extra Discussion 48 18-04-2010 20:26
Question...(Cart & Platform) drunkengamer117 OCCRA Q&A 1 16-09-2006 10:30
Question...(Cart & Platform) drunkengamer117 Rules/Strategy 0 13-09-2006 15:13
Robot with segway drive platform Andrew Rudolph Dean Kamen's Inventions 1 14-11-2003 23:54
