Go to Post We learned that no matter the outcome when you don't give up you will always win. - Koko Ed [more]
Unread 03-12-2010, 22:20
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
[FTC]: Jittering Servos
Tonight we noticed that when we enter teleop and the robot becomes enabled, all the servos jitter a small amount every second until we send a command to any 1 servo. As soon as we send a command, they quit for the rest of the match. Anyone have any idea why or how to fix this? It isn't causing any significant problems, but it does concern us.
"Don't worry, programming can fix it"
Unread 03-12-2010, 22:34
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: [FTC]: Jittering Servos
I would think that somewhere in the initialization of your program you have two conflicting commands to the servo. For instance telling the servo to be in two places at once. Do you have a copy of your code, if you could send it to me and have a brief description I would be happy to help.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 03-12-2010, 23:06
AKA: Bobby
I'm afraid I do not have a copy with me right now. I will check tomorrow for conflicts, but from what I could tell, it was all the servos, not just one. I find it hard to believe I have conflicts with every servo during startup, because it doesn't happen if the robot is disabled. Ex. when we switch out of auto and go to teleop, but before we gain control of the robot, the robot does not jitter, even though the teleop program is running, but once we gain control, we begin to jitter until we send any 1 servo a command, then all of them stop jittering. They are jittering in the correct positions, and i know servos technically always jitter back and forth, but not a visible degree from a distance like this.
[FTC]: How to run servos with LABview? Putney FIRST Tech Challenge 0 14-01-2010 12:05
[FTC]: Labview - Servos crollison FIRST Tech Challenge 2 13-11-2009 10:38
[FTC]: Servos jamie_1930 FIRST Tech Challenge 0 10-11-2009 15:38
[FTC]: Servos saaby FIRST Tech Challenge 6 31-01-2009 20:38
[FTC]: [FTC]: Can any one explain to me just how powerful the servos are? sullivan_owns FIRST Tech Challenge 19 02-12-2008 16:06
