Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
  #76   Spotlight this post!
Unread 09-01-2011, 00:19
Natesbug73 Natesbug73 is offline
FRC #3168
Natesbug73 is an unknown quantity at this point
Re: iPhone Driver Station, No Computer Needed
Has anyone heard whether this is legal to use in competition? I can't see why it wouldn't be, is there anything that says you [i]have[i]to use the netbook and joysticks?
Technology is ever changing, and the fact that a team has created a virtual driver station using a technology that so many members already own should be embraced!!
  #77   Spotlight this post!
Unread 09-01-2011, 00:57
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Originally Posted by 2bkrul View Post
That is epic. The only question is...can we use it in competition
You would have to ask on the Rules Q&A, but I don't see any chance of this being allowed. The app doesn't support communicating with the Field Management System and there is no Ethernet plug on your iPhone to plug it into the field.
Rule R52 in Section 4 of the Rules pretty clearly disallows the app in its current form...
One D-Link DAP-1522 is the only permitted mechanism for communicating to and from the ROBOT during the MATCH. All signals must originate from the OPERATOR CONSOLE and/or the Field Management System, and be transmitted to the ROBOT via the official ARENA hardware. No other form of wireless communications shall be used to communicate to, from or within the ROBOT (e.g. radio modems from previous FIRST competitions and Bluetooth devices are not permitted on the ROBOT during competition).
-Joe
  #78   Spotlight this post!
Unread 09-01-2011, 03:07
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
Originally Posted by Patrickwhite View Post
With the new driver station software, are there any updates that render this unusable for the time being? It would be nice to have this able to run the kit bot from day one [two I suppose].
More on this when I am able to test, because I dont know if their protocol has changed with the season update, I will keep you/everybody informed.
As for using this in a competiton
NO
this is dis-allowed on a couple fronts, mainly the fact that there are no wireless communications allowed on the field other than the robots. The only way this would be allowed as an actual, legal control method, is if the application outputted necessary information via the connection port, and that data was then processed by a micro-controller of some sort with an Ethernet connection and then sent to the FMS. While that is kind of an annoying way to do it, I have been looking into the possibility/plausibility/practicality of the system.
  #79   Spotlight this post!
Unread 09-01-2011, 03:23
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Wow. This is amazing stuff!
Even though it's probably not going to be allowed in the competitions, can you give us a brief (or long, whatever works) description of how you got this to work? Did you just capture packets and got the app to emulate sending them out? (Because last year, we tried to write our own customized dashboard using Java and we couldn't figure out how the communication works.) Thanks!
  #80   Spotlight this post!
Unread 05-10-2011, 13:08
twiggzee twiggzee is offline
FRC #3502 (Octo-(PI)-Rates)
Rookie Year: 2011
twiggzee is an unknown quantity at this point
has there been any luck with an android version of this yet?
Wendy
Team 3502
  #81   Spotlight this post!
Unread 05-10-2011, 15:54
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
I know someone on our team is (was?) working on something (albeit rather slowly). He's been rather busy though, and if you want to finish it, you can have a rather simple joystick only driver (and do send the patch/pull request back to him). You'd only need to hook up the joysticks to the sending function (based off ZomB) Its on Bitbucket: https://bitbucket.org/Ancantus/android_zomb
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
  #82   Spotlight this post!
Unread 22-03-2013, 19:36
dexteryoki dexteryoki is offline
FRC #3267
dexteryoki is an unknown quantity at this point
When i search for this app, iTunes says that they removed it from the store. Does anyone know why?
  #83   Spotlight this post!
Unread 26-03-2013, 19:23
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
I haven't been able to find this app either. Does anyone know what happened to it?
  #84   Spotlight this post!
Unread 26-03-2013, 22:27
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
Team Role: Leadership
Rookie Year: 2011
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
From the YouTube video on this:
Originally Posted by cometsrobotics
Sorry, it's no longer available in the app store, due to the fee to stay in the apple developer program.
https://www.youtube.com/watch?v=69hdTUtH85k
Driver Station? qpang FRC Control System 2 27-01-2010 16:59
Personal Computer Problem With FRC Driver Station Pewter_Newb General Forum 2 19-01-2010 23:26
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
