Go to Post Shouldn't we be encouraging exploration instead of repeatedly beating it with a stick? - Mike Soukup [more]
Unread 12-07-2010, 08:09 PM
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
need to change main target
I have just completed a project in Java and checked for no syntax errors. While running the project, the console states that there is no .jar file and that the cRIO address is at 10.0.0.2. I understand that the cRIO address should be 10.8.10.2 (team 810) and there probably should be a .jar to execute the code im deploying.
How do i change the IP target in the main class to the proper IP, and if this is a problem, which .jar file should i place in order to correct the error.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 12-10-2010, 06:12 PM
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: need to change main target
When compiling and running code based on wpilibj, usually the warning 'no to.jar specified' or something similar appears, it has never presented a problem to us in the past.
If you are using NetBeans for development, you need to set the team number in Tools Menu > Options dialog box > Miscellaneous tab > FRC Configuration Tab. Once you change that the IDE will automatically start deploying to the correct IP.
Do we need a main regulator jaketessem Pneumatics 6 03-28-2010 08:08 PM
Team 39: Target AND Field Oriented Drive (Target tracking) TotalChaos Robot Showcase 13 03-02-2010 03:55 PM
Change CMU target on the fly kmazh Programming 3 01-12-2006 11:17 PM
Need to change your username? Brandon Martus CD Forum Support 0 10-31-2003 12:02 AM
