Go to Post only here would you find someone calling a motor cute.... - Denman [more]
Unread 07-12-2010, 23:44
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: strong composites for belly pan
You might ask yourself if the belly pan needs to provide rigidity, or if it just needs to house electronics. In the past years, we have always used a box al welded frame and 1/8" lexan. The frame is solid without the lexan.
If you decide you still want to go with a rigid "belly pan":
I can give a +1 on garolite. I've always heard that it is about 90% the strength of carbon fiber. Machines just like carbon fiber or fiberglass in my experience.
As per your techno, if it is similar to the new one we got here, it can cut aluminium using a carbide endmil, and if you want some suggestions on speeds and feeds, I can give you first hand exerpience with a techno router. It's not fast, but it can be done if you decide that is what you want.
One other thing I remember hearing while lurking the forums was a suggestion to use a high quaility 5 ply 1/2" plywood. It's rigid and easy to work with.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
pan/tilt connection for 2007 camera kasemodz Programming 5 21-01-2007 14:21
Team 104's succcessful use of composites Gdeaver Technical Discussion 9 05-03-2005 21:40
Graphite Composites Odlaw Kit & Additional Hardware 6 26-01-2005 08:18
pic: IRI 2003 Belly Check CD47-Bot Extra Discussion 17 24-07-2003 16:49
Composites Simon G Technical Discussion 2 18-01-2002 01:43
