Go to Post Sure, whining is easier than working, but what's more rewarding? - PayneTrain [more]
Unread 08-12-2010, 12:23
austinious austinious is offline
FRC #3567
austinious is an unknown quantity at this point
Using JCreator instead of NetBeans
Rookie Team 3567 Here
I used to use NetBeans before they changed way back when to be more like Eclipse, cumbersome.
I switched to JCreator LE which is a nice simple compiler. I've searched but there is almost no info on using anything other than NetBeans.
Has anyone figured out how to use a IDE other than Eclipse or NetBeans?
using an IDE other than NetBeans for Java isaacdl Programming 12 14-06-2010 22:42
Gyro instead of GTS windell747 Electrical 3 13-02-2008 08:22
Has anyone keyed IFI wheels instead of using the bearings? Dasistmeinmoped Technical Discussion 3 24-01-2007 00:03
SERAL INSTEAD OF DEBUG... EGG0900 Programming 2 05-11-2005 18:25
Instead of Castors .... shyra1353 General Forum 4 20-02-2004 14:29
