Go to Post Winning is an outcome, not the whole point. - StephLee [more]
Unread 08-12-2010, 15:04
team3329 team3329 is offline
None #3329
team3329 is an unknown quantity at this point
Jag/ CIM compatability problem
We decided to attempt a four wheel direct drive system for the time being and to run some tests with it. However, one of the four jags given to us is not turning it's respective motor. The light indicating the direction is toggling back and forth as commanded, however we are getting no response in the motor. Nothing. does anyone have any clue why?
Unread 08-12-2010, 15:10
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Jag/ CIM compatability problem
Got an analog voltmeter? Set it for DC (the smallest range larger than 12V) and probe the suspect Jag's output and see what voltage you are getting for full command in each direction. Do the same for one of the Jags that is working properly.
Report what you find.
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
My Robot Compatability Chart Michael Hill General Forum 10 19-02-2005 04:05
2005 code and IDE compatability? Phil Roth Programming 4 08-01-2005 22:30
RCX compatability peterbb Lego Mindstorm Discussion 2 26-12-2004 18:00
