Go to Post This may not be Battlebots but it sure isn't Pretty Pretty Princess Bots. - Andrew Schreiber [more]
Unread 08-12-2010, 22:32
team3329 team3329 is offline
None #3329
team3329 is an unknown quantity at this point
CIM/ Jag power help
Having some issues with Jag compatibility and our CIM motors. We are thinking of using a 4 wheel direct drive with mechanum wheels to test, but our Jags are running the motors slow on 3 and not at all on 1. Is it a power distribution problem?
Unread 08-12-2010, 22:35
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: CIM/ Jag power help
There's no "h" in mecanum.
Are you using PWM or CAN to command the Jags ?
Unread 08-12-2010, 22:43
None #3329
PWM. What is CAN? We are extremely new to this. 2010 was our first year, and we pretty much followed the instruction manual and figured it out as we went. Not too familiar with terms yet....
Unread 08-12-2010, 22:47
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
Rookie Year: 2007
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
I would suggest just the basic diagnostics first:
Check your voltages in to the jags (should be >=12 with a charged battery)
Check voltages out from the jags (should be ~0 when joystick is 0, should be >=12 when full forward)
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 08-12-2010, 22:58
Ether's Avatar
Rookie Year: 1969
There's a small ongoing discussion about this in another thread. So may I ask, have you personally actually done this ? If so, what type of meter* did you use and what range** did you set it for ?
* i.e. analog or digital or oscilloscope etc
** e.g. 0 to 15VDC or VAC etc
Unread 08-12-2010, 23:12
Ether's Avatar
Rookie Year: 1969
PWM.
Have you looked at the Dashboard to confirm that your software is indeed commanding full throttle?
Have you measured the voltages at the Jag's output and power input at full throttle?
Have you measured the CIM's current at full throttle?
Unread 08-12-2010, 23:17
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
Just a regular digital multimeter. We have checked this whenever we have trouble and this is the behavior we see. (The multimeter is autoranging, so not range setting)
Unread 08-12-2010, 23:20
Ether's Avatar
Rookie Year: 1969
Does the meter have a setting for selecting DC or AC? If so, what setting was it on?
You don't happen to remember the brand and model number by any chance, do you?
Unread 08-12-2010, 23:21
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
Yeah, we set it on DC.
I know it was a Fluke brand, not sure about the model number though. I can get the model number and confirm the behavior tomorrow. Maybe hook it up to an oscilloscope too.
Edit: Looking at Fluke's website, I'm fairly certain it is the Fluke 114
Unread 09-12-2010, 02:21
ErikRantapaa ErikRantapaa is offline
FRC #2532 (Flash Power)
Rookie Year: 2010
ErikRantapaa is an unknown quantity at this point
A scope certainly would be able to tell you if the Jag is trying to drive the motors correctly.
I think it would be helpful to have a hand-held PWM signal generator to be able to test Jags directly. Something like this:
http://www.rc-cam.com/servotst.htm
or this:
http://www.sentex.ca/~mec1995/gadgets/servo3.htm
Also, any hobby store should have something similar available. Google for "servo tester".
Unread 09-12-2010, 15:49
Ether's Avatar
Rookie Year: 1969
or this:
Both of those say they go from 1 to 2ms.
I think the default input PWM range for the Black Jag is 0.67 ms to 2.33 ms.
So those devices wouldn't drive a default-configured Black Jag's output to its full range.
Name:	Jag input.png
Jag/ CIM compatability problem team3329 Technical Discussion 1 08-12-2010 15:10
Help: Bevel Gear Mounted On CIM Shaft? 854 bears Motors 16 24-07-2009 13:50
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
cim motor power question Zippiot Motors 16 16-02-2005 20:40
