Good Afternoon World,
I am looking in to a sort of bicep curl hanging mechanism. This mechanism involves gripping the side of the ladder, and rotating the robot up in to a low hang position. Does anyone have a good idea for something to grab on to the arm. Thanks ESP |
Re: Vex Hanging Mechanism
If you're approaching it from the front or back, you could try extending an arm that wedges itself between two of the PVC pipes. As you lift, force exerted on both pipes holds you up. (Especially if you put a hook on the end for the top pipe)
Yeah sorry if I wasnt clear. I am trying to build a VEX hanging mechanism for the competion: Round Up
And the first answer was a great one! The only difference is that the VEX ladder has slanted rails, grab one of them and up and hang. Or reach up and grab the green rail and lever up.
One problem is getting hung up on the lower rail. Last weekend we saw the team from Christopher Dock solve that by climbing over the lower rung into the center of the ladder and then hanging on the inside. Lots of cool FRC robots have hung across the years, check them out and replicate them in VEX parts. |
Alright. How should I grab them?
| pic: 3280 Tape Measure Hanging Mechanism | JamesBrown | Extra Discussion | 25 | 30-01-2016 20:49 |
| [OCCRA]: VEX hanging time | Kettering | OCCRA Q&A | 1 | 20-10-2010 08:53 |
| Hanging Mechanism Material | alex33zebras | Technical Discussion | 7 | 28-01-2010 13:45 |
| Extension Mechanism | acer_7 | Technical Discussion | 31 | 09-06-2006 18:02 |
| hanging off off other robots that are hanging off the horiz bar | Andrew Dahl | Rules/Strategy | 15 | 12-01-2004 19:14 |
