Go to Post FIRST isn't about building robots. I know. But I also know that Inspiration comes in a lot of flavors and I, for one, believe it is a lot easier to inspire my kids when we set "playing after lunch on Saturday" as a worthy team goal. - Joe Johnson [more]
Unread 10-12-2010, 16:10
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
random segfault
I appear to be encountering a very odd segfault. I have this method, and some odd output.
Methods:
Code:
string ZomBDashboard::GetString(string name)
    if (src != NULL)
        debugf("Getting string.. (Deref: %p;", src);
        System451::Communication::Dashboard::ZomBTCPSource &ts = *((System451::Communication::Dashboard::ZomBTCPSource*)src);
        debugf(" deref OK, con: %d)", ts.connected);
        return ts.Get(name);//or, src->Get(name)
    return "";
const char* System451::Communication::Dashboard::ZomBTCPSource::Get(string name)
    debugf(". in, \n");
    Synchronized sync (sink);
    return curvalues[name];
Output:
Code:
Getting string.. (Deref: 0xsomememoryaddressthatappearsvalid; deref OK, con: 4)
data access
(generic vxworks error info)
and sometimes
Code:
data access
I tried using Debug Kernel Task, but WR just paused updating all the panels to new info, so it was essentially useless.
The robot code is attached in MyRobot.cpp and the C++ Bindings folder. The dashboard is Dashboard.exe and ZomB.dll (you might have to launch it twice), and when all is working, moving the slider on the left should move the slider on the right.
if you feel like compiling ZomB, download all the code (in the trunk) at http://firstforge.wpi.edu/integratio...ystem=exsy1002 and copy the DashboardDataHub.cs in the zip into ZomBdll\NetAndDataProcessing
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 11-12-2010, 16:27
byteit101's Avatar
Re: random segfault
I've debugged it some more, and I am completely confused.
a variable is changing its address without being updated!
I have the src variable, which is a pointer to a interface, and is assigned either null, or a new TCPsender. I then print out the pointer address, and it looks good.
Later, after i'm enabled and in the telop function, I call GetString, and print out the address, then try to deref src, and ultimatly fail because somehow, src changed even though those are the only two active lines of code that reference src.
Output attached (how does one copy and paste the text from the NetConsole? I could not get a sticking selection)
Code:
Code:
        void OperatorControl(void)
            cerr<<"IN oc"<<endl;
            int loops=0;
            while (IsEnabled())
                cerr<<"looping";
                cerr<<zb.GetString("ival")<<endl;
Constructor
Code:
    if ((mode & RemoteData) == RemoteData)
        src = new System451::Communication::Dashboard::ZomBTCPSource();
    else
        src = 0;
    debugf("init: src=%p\r\n", src);
Code:
    if (src)
        debugf("\r\ngsi: src=%p\r\n", src);
        return src->Get(name);
    return "";
Watchdog.Kill();
Unread 11-12-2010, 17:55
byteit101's Avatar
Re: random segfault
Ah! Copy constructors! gotta love (read: hate) them!
Watchdog.Kill();
Unread 11-12-2010, 22:44
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: random segfault
Just select the text... when you let go, it's copied. To paste, middle click.
-Joe
Unread 12-12-2010, 02:39
Rookie Year: 1997
Re: random segfault
-Joe
By the way, the reason for this is so that you can hit <ctrl-c> and it will send that code to the cRIO instead of being processed by the console window.
Random? TexasFederation Programming 1 16-09-2007 13:47
Random Stuff Brm789 Chit-Chat 11 20-11-2003 16:13
How random is random???? archiver 1999 0 23-06-2002 21:59
Random Marc P. Chit-Chat 138 13-02-2002 15:11
Random Question... Jessica Boucher Chit-Chat 26 02-07-2001 21:37
