Go to Post I also hate it when I keep seeing this message: "You must spread some Reputation around before giving it to Andy Baker again." - dlavery [more]
Unread 10-12-2010, 21:34
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
FRC #0973 (Greybots)
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Bimba Spring Supershifter Piston
So today we started making a universal test chassis for our programmers to implement on before and during competition. With these new spring loaded pistons, when you are extending the shaft, does a constant supply of pressure need to be added to the piston?
Meaning that when the piston is extended, is it still putting more air into it and having a constant charge to the compressor to keep it filled?
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 10-12-2010, 21:38
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bimba Spring Supershifter Piston
With spring-return pneumatic cylinders I am familiar with, the usual practice is to extend the piston by pressurizing the cylinder (they usually have only one 'hole' for air) and then commanding your solenoid valve to "close", maintaining the pressure. You then open it when you want it to retract.
You might need a different kind of solenoid valve (compared to the KoP version) to do this.
Unread 10-12-2010, 21:44
rcmolloy's Avatar
So when your maintaining pressure, the piston is basically being held in with a constant flow of air coming out?
If I could rephrase the question, can the piston have two fixed positions one being fully extended and one being fully retracted without having to keep a constant flow of air.
Unread 10-12-2010, 21:48
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
When the cylinder is extended, the volume that the pressurized air in your pneumatic system must fill increases (because pressurized air needs to fill the inside of the cylinder behind the plunger). Once the entire system (on the working side of the regulator) reaches the desired pressure level, there is no need to keep the compressor running except to replenish any air lost due to leaks.
This goes for both double-acting and spring-return cylinders - once you are extended, all you need to do is maintain pressure.
Unread 10-12-2010, 21:49
Yes. Air only "flows" when you are in the act of extending or retracting the cylinder. Once it is in place, all you need to do is maintain a constant pressure level and you're golden.
Unread 10-12-2010, 22:00
rcmolloy's Avatar
Ahhh ok. We weren't sure if they acted like regular pistons but it does. The spring just allows it to retract faster because of the "shifting on the fly" allowance.
Thanks guys
Unread 10-12-2010, 23:26
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
The cylinder will consume no air after it is extended, the pressure holding it is static. You will want to maintain extend pressure (valve actuated) so the holding force is maintained. When retracted (valve exhausted) the cylinder will be vented and the spring will supply the only return force. A spring return cylinder consumes 1/2 of the air (actually a little more than 1/2 due to the rod volume) of a double-acting cylinder.
Unread 11-12-2010, 08:21
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Think of it like a balloon. When you fill a balloon with air you tie it up and it stays full, you don't need to add more air.
Spring loaded Pneumatic piston Team2191 Technical Discussion 17 15-01-2010 23:51
AM SuperShifter in Inventor ADZDEBLICK Inventor 17 02-01-2008 05:25
Nut for Bimba Piston chris31 Pneumatics 6 29-07-2007 21:30
spring piston Matt21q General Forum 2 02-02-2007 23:44
spring piston? Matt21q Technical Discussion 2 02-02-2007 17:02
