Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Go Back   Chief Delphi > Technical > CAD
Unread 10-12-2010, 23:12
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
CAD tutorials?
I was CADing today at home and was out of ideas of what to CAD so if any one has any good FIRST related CAD ideas please shoot them to me. Also if any one has a good list of Soildworks tutorials that they could share with me, I would greatly appreciate it. I am fairly good at CAD I know my way around an assembly and parts very well but I am looking for new techniques that would help me out during build season.
Thank you
Unread 11-12-2010, 01:46
biancs15's Avatar
biancs15 biancs15 is offline
Driver, Design and Manufacturing
AKA: Austin
FRC #0610 (Coyotes)
Team Role: Leadership
biancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to behold
Re: CAD tutorials?
Matt,
There are a set of tutorials built into SolidWorks itself. On the right side of the screen in a part file there is a rectangular box. In that box there is a link that says tutorials. This will open a set of tutorials of all ranges of difficulty.
Some ideas of pieces to make to truly test you're abilities are:
Wii Remote (nun chuck optional)
GameBoy XP
Xbox controller
A chair
A lamp of some sort (the fancier the better)
A pit area for you're team to set up when the competitions start
A room in you're house
An 8 wheel drive base
Make lego pieces and try to assemble them to make something
Some of these are not FIRST related, however they help in achieving knowledge of what you can do in SolidWorks.
Hope this helps.
Sincerely,
Austin
2013 Team Co-Captain, Base driver, Head of Design and Manufacturing
2013 Waterloo Regional Finalists
2013 BAE Systems Regional Winners
2012 Arizona Regional Winners
2012 GTR East Regional Finalists
2011 Galileo Division Finalists
2011 Waterloo Regional Finalists
2011 GTR West Regional Finalists
"When in Rome"
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Re: CAD tutorials?
One skill that I always find useful is being able to express a design wholly in a single sketch, in order to test it out without spending the extra time to actually model it all up.
With that being said, try designing a pneumatic claw. I'd start by drawing up the basic design in a sketch, and once I had worked out all the details, then using what I learned from my sketch to make all the parts. One of the more fun designs I made in 2007 was a pneumatic claw that also had two pistons to rotate the claw 90 degrees to the left and to the right.
Things like 4 bar linkages are fun to try to design. It's easiest to design them first in a sketch, and then make the parts for real.
If you use sheet metal, another fun trick that my brother taught me is that you can model up something using the thickness of paper as the sheet metal thickness, print it out at full scale, cut it out, bend it along the lines, and then glue it together. You can test all sorts of intricate sheet metal creations that way.
Good luck!
Unread 11-12-2010, 11:54
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: CAD tutorials?
We just created new tutorials for FIRST both FRC and FLL. These use actual robot parts
go to www.SolidWorks.com/robotics
Each tutorial gives you a video how to and the the model files before and after.
Also, use the tutorials inside of SolidWorks, go to Help, SolidWorks Tutorials
All the robot models that we have for FRC, FTC (Tetrix), VEX, and FLL are located inside of SolidWorks 2010 in the Design Library. Don't recreate the parts from Andy Mark and SMC - use the models we have made.
To link your SolidWorks so that if shows the robot libraries - follow the steps in this video
http://blogs.solidworks.com/teacher/...-and-more.html
You are doing the right thing. Now is the time to get your modeling skills up before the competition begins. Review how we have build robots. They will give you a good start.
If you dont have SolidWorks 2010, you can apply for sponsorship at www.SolidWorks.com/SponsoredDesignContest
As always, there are plenty of people on Chief Delphi to support your SolidWorks questions, dont be afraid to ask - that is how you learn.
Good luck
Marie
Unread 14-12-2010, 16:57
MattC9's Avatar
Re: CAD tutorials?
Thank you all this has been wonderful help especially the CAD library from solidworks it self. I have gone and re done my 6WD with bumper mounts and all (no electrons). But one last Question I had was how do you design something to be welded? I just mate the part and insert weld marks. The reason I ask is that my team is planing to try and start welding this year. Are there any special things we need to do for it?
Unread 14-12-2010, 22:21
MattC9's Avatar
Re: CAD tutorials?
Ok i found out how to attach a picture to a post!!! So here is the 6WD. I posted the first rev. the other day but this is what i have done for the 6WD
Unread 22-12-2010, 23:49
Re: CAD tutorials?
There is a weldment tutorial in SolidWorks. Select Help, SolidWorks Tutorials.
This tutorial will teach you basic techniques. Marie
NI Tutorials comphappy Programming 0 18-08-2008 00:36
Tutorials RRA4LIFE2 Programming 1 06-01-2008 09:21
Multimedia Tutorials AndyB Website Design/Showcase 2 20-01-2006 22:11
Tutorials Leon Machado IV 3D Animation and Competition 13 25-01-2004 23:10
Delphi6 Tutorials OrangeKoolAid Programming 4 18-05-2002 05:49
