Go to Post I just weighed myself and I have gained two pounds since last Saturday. Thats a sign of a good robotics team. - russell [more]
Unread 11-12-2010, 12:34
pschre's Avatar
pschre pschre is offline
Teacher Coach
AKA: James Schreiner
FRC #0806 (Brooklyn Blacksmiths)
Team Role: Coach
pschre will become famous soon enoughpschre will become famous soon enough
Send a message via AIM to pschre
Digital I/O putting out +5V when robot disabled
Our technical mentor and rookies were trying out code to put our compressor on a toggle (joystick button). it is plugged into a digital i/o and not a relay port. But when we first power up the robot, and our teleop is still disabled, we are getting +5 to the Spike which is powering the compressor. We do not have the pressure switch wired. Can anyone explain why the digital i/o is doing this when the robot is disabled, and what we can do to fix it?
"In this life we cannot do great things. We can only do small things with great love." -- Mother Teresa
"You give yourself to us, O Lord, then selfless let us be, to serve each other in Your name, in truth and charity." -- Robert E. Kreutz, You Satisfy the Hungry Heart
"You have the right to work, but for the work's sake only. You have no rights to the fruits of work. Desire for the fruits of work must never be your motive in working. Never give way to laziness, either...Work done with anxiety about results is far inferior to work done without such anxiety, in the calm of self-surrender...They who work selfishly for results are miserable." -- from the Bhagavad Gita, quoted in Educating Esmé
Unread 11-12-2010, 12:52
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Digital I/O putting out +5V when robot disabled
Per section 3.4.3 of the control system manual, the digitial IO pins have a 10k pullup to 5v.
The easiest way to solve this would be to run the spike from a relay port as intended. What is the reason you're trying to run it from a digital output?
If you're just trying to show that you can control a digital output, what about using an LED?
Unread 11-12-2010, 14:36
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Your configuration is illegal* and would not pass inspection. You may only control spike relays using the designated relay ports.
* I know I'm supposed to give the standard "previous rules don't apply to future years, but trust me on this one.
Unread 13-12-2010, 18:54
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
i can't imaging the rules for that changing anyways
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
putting placards on the robot Rafael2215 Rules/Strategy 10 13-03-2010 16:31
Digital Sidecar Fails When Limit Switch is Pressed diggoran FRC Control System 3 13-02-2010 16:19
Robot seems to be Disabled when using Jaguars Thxe C/C++ 2 11-02-2009 22:01
Disabled Robot Scoring? DM7000 Rules/Strategy 15 09-01-2009 21:50
