Go to Post if you've got the guts you will get the job done. - JamesCH95 [more]
Unread 12-12-2010, 23:32
Coach Doug Coach Doug is offline
FTC #3529
Coach Doug is an unknown quantity at this point
[FTC]: Samantha - installation recommendations
My team just competed this past weekend - we implemented all the recommendations per the FTC email blast - but we had the pleasure of watching a scoring/active robot become a paperweight.
I am looking for tips/pictures of how other teams who HAVE competed and experienced no issues. Practicing on your own field does simulate the bumps from the field obstacles but not the robot bumping etc.
Overall, I like the Samantha but losing two matches due to it is tough to handle.
Also, is there a way to monitor the charge on the 12vdc battery?
Unread 13-12-2010, 07:32
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: [FTC]: Samantha - installation recommendations
Greetings Doug,
Sorry to hear you had trouble over the weekend. How do you know it was Sam that went out on you? We saw a few communications issues in the large dark tent that was the Richmond Qualifier, but none of them were from the Samantha module. 2 of them were from the NXT freezing and the other was due to a bad power connection.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 13-12-2010, 16:34
FTC #3529
I don't believe so - never had a " frozen " nxt during 4 yrs of FLL nor last year with the ftc bluetooth connection. I am basing my impressions probably more on urban legend than fact - I do know that there are many out there who have experienced this and more who have not. The keys are solid usb connection, robust power wire attachments, power > x volts, and i would assume a solid surface to connect to also.
We can improve the solid surface to connect to - probably has some diving board effect but not much - after that I am grasping at straws on what to tell the team implement to avoid this next time.
Unread 14-12-2010, 02:19
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
We mounted ours horizontal and as high as we could.
And as far as I know, we had no problems at the LA tournament yesterday.
The NXT screen displays the following information on its screen when using the required programming templates:
Code:
Line 1: [Wait for start | TeleOp Running | Auton Running]
Line 2:
Line 3: Ext Batt: (The 12v battery voltage)
Line 4: NXT Batt: (The NXT's battery voltage)
Line 5: FMS Msgs: (The # of FMS messages recieved)
Line 6: Teleop FileName:
Line 7: (Teleop_FileName.rxe)
If you want to know it in your code then it is (at least in robotc)
Code:
externalBatteryAvg / (float) 1000;
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
[FTC]: Samantha instructions Sasha FIRST Tech Challenge 12 20-07-2012 19:02
[FTC]: Samantha issues at VCU FRC/FTC workshops - how to fix cybiko123 FIRST Tech Challenge 3 13-12-2010 13:18
[FTC]: samantha issues johncap100 FIRST Tech Challenge 0 02-11-2010 17:17
[FTC]: samantha johncap100 FIRST Tech Challenge 4 01-11-2010 21:25
[FTC]: FTC Samantha Unit Setup With WRT610N robotic321 FIRST Tech Challenge 0 21-10-2010 15:23
