Go to Post What really drove us was not our achievements, but our failures. - BEEKMAN [more]
Unread 14-12-2010, 17:50
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Labview Potentiometer Control
We're a couple of never-ever programmers trying to teach ourselves LabView (in the next month...) Can someone help us out with some sample code for a trim potentiometer?
We added an analogue Open into Begin.vi (and gave it a unique DevRefNum based on some sample code for a limit switch), then tried to read values from the Get Voltage vi in the teleop.vi (inside the main loop)...
We added a probe to the output of the Get Voltage vi, and it just fluctuates around zero (looks like noise) no matter what the potentiometer does. (The pot is in analogue 1, and we identified it as such in the code.)
Thus, if someone has some sample code they would be willing to share, that would be fantastic.
Thanks,
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 14-12-2010, 17:55
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Labview Potentiometer Control
Thanks,
Patrick
How is the potentiometer connected to the cRIO (ie where is each wire going)? Have you measured the pot's signal with a simple voltmeter to ascertain for certain that it is actually providing a signal?
Unread 14-12-2010, 18:15
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Thanks,
Patrick
If it looks like you are getting noise, you probably are - I'm betting that your code is just fine.
Wire one end of the pot to +5V, the other end to ground, and the middle to the signal input. These should be labeled on the shell for the analog breakout.
Unread 14-12-2010, 23:15
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
The 5v voltage regulator does have a certain degree of noise.
On the 2009 Analog Breakout, I measured about +-15mv of variation.
Granted, the regulator was changed to a linear regulator for 2010, so the noise should be less. However, there's a lot of switcher power supplies on the robot (I count 5, excluding any motor controllers). There's probably a lot of noise on the main supply because of this.
-- Marshal Horn
Unread 15-12-2010, 12:02
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
Rookie Year: 2007
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Thanks,
Patrick
Patrick,
I would be really helpful if you could post a screenshot of the relevant part of your code and a picture showing how you connected the potentiometer to the cRio
it seems like your connection is wrong and you are measuring an input that is not connected to anything.
regards,
Borna
-Borna Emami
Team 0x27
Unread 15-12-2010, 12:22
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Above should be the your first step in troubleshooting this problem! So often we overlook the basics and jump to the advanced steps.
1) Verify the pot actually works.
2) Verify it is connected correctly.
3) See if the code reads as expected.
To address step #2 above, make sure the pot is connected to the analog bumper as follows:
One end of the pot is connected to the black wire of a PWM cable. The other end of that black wire needs to be connected to the Gnd. pin on the analog input you selected.
The other end of the pot needs to be connected th the red wire of the same PWM cable. The other end needs to be connected to the +5v pin of the analog input.
Now the wiper of the pot needs to be connected to the white wire of the PWM cable. The other end of the white wire needs to be connected to the Signal pin of the selected analog input.
With these steps verified, you can now use a "probe" to see if the code is working properly.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 15-12-2010, 13:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
One more thing -- make sure the Analog Breakout has 12 volt power. Its green light should be lit. Without that, it won't be able to supply 5 volts to the potentiometer.
Unread 16-12-2010, 11:48
pfreivald's Avatar
Just able to get back to this -- very busy week!
Looks like the problem might be wiring. I'll get the electrical kids on that pronto and see where we're at. Thanks for the help, everyone!
Team 1551
I write books, too!
Position Control using potentiometer? biojae CAN 13 03-02-2010 20:12
Labview Servo Control Issue EricWilliams Programming 5 22-01-2010 14:24
Labview motor control seanl Programming 5 11-02-2009 17:02
Labview Revision Control Joe Ross National Instruments LabVIEW and Data Acquisition 2 11-05-2008 17:28
Potentiometer arm control Hazmatt Programming 15 01-04-2008 21:27
