Go to Post Please look around the forum, I believe this clue is already under discussion and has been overly dissected. - ttldomination [more]
Unread 16-12-2010, 10:14
gilkeedman gilkeedman is offline
Team captain/Pneumatics/Mechanics
AKA: Gil 'Dil Tedem' Kedem
FRC #2630 (Thunderbolts)
Rookie Year: 2007
gilkeedman is an unknown quantity at this point
Where can we find good pneumatic wheels?
Me and my team trying to learn about good and diffrent drivetrains than those we used in the past few years and we want to see more about pneumatic wheels (for example 1114 wheels at 2010)
so those anybody can help us to find good pneumatic wheels?
2007 - Israeli regional FLL team member, 2008 - Fomula Green-8075 FLL team member, Israel's champions
2009 - Israel FLL referee and Thunderbolts team member
2010 - Thunderbolts, Israeli regional champions, Curie semifinals
2011 - Thunderbolts captain
Thunderbolts 2630 website!!
Unread 16-12-2010, 11:29
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Where can we find good pneumatic wheels?
50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary.
Unread 16-12-2010, 11:44
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
"You must spread some Reputation around before giving it to Joe Ross again."
That's an awesome stat Joe.
GitHub
Unread 16-12-2010, 13:58
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Wow, just wow!
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 16-12-2010, 15:05
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
It should also be noted that:
1) Said wheel does need some hub modifications to use in FRC--the stock hub configuration has a hard time with attaching a sprocket.
2) Spare tires are a must if you do drive practice. A lot of those tires showed red (and inner lining) by the end of the season, and the batteries were constantly on the charger due to the amount of drive practice put on them.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 17-12-2010, 14:19
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Any pictures or drawings of how you did the hub modification? Did you actually modify the hub or fabricate an adapter between the hub and the sprocket.
-T
Unread 17-12-2010, 14:53
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
I forget how we did it in 2005, but the hub itself is 3-4 pieces. 2 of them are rims, sandwiched between hub pieces. The hub pieces get modified/replaced.
In 2006-2008, we used a custom adapter to hold the rims in place, and a spacer to keep the sprockets separate. I don't have plans or pictures readily available; ShaneP might have some better ones.
Oh, and using 6 of these wheels on a 6WD is asking for turning problems, even with a dropped center wheel.
Past teams:
Unread 19-12-2010, 00:51
topgun's Avatar
What kind of turning problems? Slow, or bumping, or fuse blowing?
Or are you saying you don't use 6 of these wheels on a 6WD?
How do you overcome the turning problems?
-T
Unread 19-12-2010, 13:07
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
http://www.radioflyer.com/22w-0642699.html?sid=5
with slight modification these work pretty well. they are light and durable as well.
in past years my team has mad an axle with a disk on it, then the radio flyer wheel is bolted to the disk in a similar manner as a car wheel.
Unread 12-01-2011, 12:13
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Can anyone supply some information for me about the mcmaster wheels mentioned by 330. Part number: 2717T51 We are looking at these as a high CoF option for our drivetrain this year.
What I am looking for:
Mostly design of the stock hub/rim. Searching the web eludes to that all pneumatic casters are very similar, if not the same hub design. I was unable to find a model, or drawing.
I'm curious on what the size of the 4 bolt circle is.
Also, I am looking for the size and length of the shaft part of the wheel. (I do not mean interior dimension, but outside dimension so that you could machine a hub and and insert it over.)
Thanks in advance.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 12-01-2011, 12:45
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Rims are Al, curved, with the 4-hole pattern. I think the hole pattern was on a 1.5" radius circle, but I'm not quite sure.
Not sure on shaft portion, but I do know that 330 did custom hubs. They might still have the CAD around. I'm not sure I have access to the repository anymore; you'd be better off asking one of the other 330 members.
Past teams:
Unread 22-01-2011, 12:48
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Can one of the teams that used the McMaster wheel (2717T51) last year please post the tire information for the tires you used for that wheel?
I'm looking to find out the manufacturer and model number for that tire. Thanks!!!
Team 1519 has had great success in the past using various pneumatic Skyway wheels. See http://www.skywaywheels.com/ Their wheels are available with various semi-custom hubs, see http://skywaywheels.com/products/hubs/index.html Discounting is available for FIRST teams, as described at http://skywaywheels.com/usfirst.htm
Last year, we used the Skyway WHL-428 (a 9"x2" pneumatic) on the front of our robot. Photos can be seen at http://www.chiefdelphi.com/media/photos/35102 and http://www.chiefdelphi.com/media/photos/35535. The tires on these wheels were an Innova IA-2817-4 with a size of 2.80/2.50-4. These had great grip and were extremely rugged.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Last edited by Ken Streeter : 22-01-2011 at 12:55. Reason: Added tire info for last year's Skyway wheels.
Unread 19-12-2010, 20:53
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Major bumping, several inches in the air bumping. Pneumatic tires bounce really well once you get them started, and if you keep going they bounce higher. If we're using 6 wheel drive we'll probably have plaction wheels on the corners. They slide sideways pretty well without giving up much in the way of fore-aft traction.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 22-12-2010, 01:44
Yalib Yalib is offline
Rookie Year: 2011
Yalib is on a distinguished road
Can enyone help us compare the wheels that were given above with some advanteges and disadvanteges about each? i have to say the mbs wheels looks really high quality...
  #15   Spotlight this post!
Unread 22-12-2010, 02:18
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
The McMaster ones are high-traction. Give us 2 of those as our center wheels, and we'll able to hold our own in a pushing match if needed. 4, and we'rr a bit better. They wear well, too; when you see the red, pull out the spares, but you've got a few more matches. One set could last an entire event, eliminations included, and be usable in practice later. The cost is about the same, $20 US/wheel, but McMaster is known for fast shipping if they're near your area (and willing to deal with you).
I don't know about the MBS wheels in terms of traction and wear; mountainboards aren't exactly designed for light use, though. (And they're not designed to be self-powered...)
Looking at the Radio Flyer wheels, they're more expensive (over $25/wheel) than either of the other two. Again, no real experience there.
The biggest problem with all of them is that they will need modification to work with a drive system. A sprocket needs to be attached somehow. See the explanations earlier in the thread.
If it's track record you want, McMaster wheels have a lot of regional and Championship wins, and I don't know of a single failure other than tread wear, which everybody has. I don't know about the other types mentioned.
Past teams:
Where can I find gears? vivek16 Technical Discussion 16 13-05-2008 08:38
where can I find it? kDude Control System 3 22-01-2008 17:50
Pro/E...Where can I find it? vedas Technical Discussion 4 21-04-2004 23:45
