Go to Post We can either sit around and complain about what could have been, or we can focus on the upside of what we have and move on. - Vikesrock [more]
Unread 22-12-2010, 22:25
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: Where can we find good pneumatic wheels?
Originally Posted by EricH View Post
I don't know about the MBS wheels in terms of traction and wear; mountainboards aren't exactly designed for light use, though. (And they're not designed to be self-powered...)
For what it's worth, neither are the McMaster wheels... They're for casters, no?
Mountain board wheels are high traction, but that's partly because they're designed for dirt and grass. Thus the wheels are pneumatic to increase their contact patch, since on loose non-carpet surfaces your surface area comes into play (dynamic friction due to deforming surface). So how they perform on carpet remains to be seen.
Do keep in mind traction for non driven wheels may not be the #1 priority. Scooter and inline racing wheels are a perfect size for first (90-125mm) but have a polyurethane tread with a hard 80-95A durometer to decrease wear and to allow for controlled skids.
Unread 23-12-2010, 01:42
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
The McMaster ones are high-traction. Give us 2 of those as our center wheels, and we'll able to hold our own in a pushing match if needed. 4, and we'rr a bit better. They wear well, too; when you see the red, pull out the spares, but you've got a few more matches. One set could last an entire event, eliminations included, and be usable in practice later. The cost is about the same, $20 US/wheel, but McMaster is known for fast shipping if they're near your area (and willing to deal with you).
1276 used pneumatic wheels and hubs intended for mountainboards in 2005 for our two powered rear wheels. The front two were omniwheel casters. We played in the vicinity of 10 matches (qualifying plus 3 elimination rounds), had a week of driver practice and two more years of abuse driving it on just about everything as a defender for driver practice and demo bot. They stood up just fine. I don't remember the vendor, it was just some mountainboard shop we found online.
You can barely see the top of one in the lower right.
One of the reasons we gave up on pneumatic wheels was they make driving straight (especially in autonomous) a really big pain in the butt. We found how straight we drove could be impacted hugely by a relatively small difference in tire pressure. We found it much simpler to drive in a relatively straight line once we made the switch to solid wheels. YMMV, or you might actually finish on time so you have time to test better code!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 22-12-2010, 17:40
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Originally Posted by ChrisH View Post
Major bumping, several inches in the air bumping. Pneumatic tires bounce really well once you get them started, and if you keep going they bounce higher. If we're using 6 wheel drive we'll probably have plaction wheels on the corners. They slide sideways pretty well without giving up much in the way of fore-aft traction.
If everyone was havng problems with 6WD why was 1114 moving so easily with 8WD (2010).
Unread 22-12-2010, 17:51
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
I would be very surprised if 1114 had all 8 wheels in the same plane. I bet that the center four wheels were dropped slightly, on the order of 1/8".
Unread 22-12-2010, 18:31
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
And that made the wheelbase shorter than ours in 2006, where we had very little drop and 6 wheels. Long wheelbase=tougher turning, in general. This is why most 6WD robots have a dropped center wheel or omnis (or other low-friction wheels) on the corners. We didn't have nearly as much trouble after putting Skyways on the front corners.
Link to the McMaster wheels: go to the McMaster site and enter the part number into the search box. You'll get the page; the wheels are near the bottom. We used the gray treaded ones.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 22-12-2010, 23:15
Unsung FIRST Hero
Karthik Karthik is offline
VEX Robotics GDC Chairman
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
There's considerably less "bounce" in the 8WD we had compared to the 6WD that 330 employed with the same wheels. If construct a polygon between the centres of our wheels this year (or any standard 8WD) so get an upside down trapezoid. If you do the same with a 6WD you get a triangle resting on a vertex. Looking at these shapes, it's easy to see why one would have more rock, and thus more bounce.
Austin is correct. Here's a picture where our drop is depicted pretty clearly.
http://www.simbotics.org/resources/g...l/_3260103.jpg
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 19-12-2010, 15:01
AKA: Pinecone
Oh, and using 6 of these wheels on a 6WD is asking for turning problems, even with a dropped center wheel.
Tell that to 70, 494, 469, 1114, and 2370 last year. 2370 actually used four pneumatic wheels in the long configuration - and turned just fine, somehow! I'll never understand that.
Unread 19-12-2010, 19:14
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Chris, I said 6 of those wheels in a 6WD drop, in 2006. We had trouble turning. I don't know if there is any video of the Arizona practice rounds around, but we bounced around a bit.
Solution: the front wheels, which were the primary off-ground wheels (6WD drop drives rock a bit, but can be weighted so one set or the other is mainly on the ground), were replaced with 6" Skyways. No more problems. In 2005 we used 6" Skyways on the corners; in 2007 we broke quite a few AM hubs on our rear wheels, but not so many on the front wheels. (We also caught a hub that had partially failed. Mark Koors happened to be the FTA at the event, so he got a wheel in the process of failing for analysis.) 2008 saw the revised AM 6" wheels on the corners.
Past teams:
Unread 22-12-2010, 23:38
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Didn't 70/494 have a crab drive in the wide direction?
Unread 23-12-2010, 08:13
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Yes.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at Standish and West MI in 2016)
FTC 6043 & 7911 (Competing at West MI and Allendale in 2015)
Unread 23-12-2010, 11:11
Jay TenBrink Jay TenBrink is offline
FRC #0494 (Martians)
Jay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond reputeJay TenBrink has a reputation beyond repute
When we were in skid steer mode we had a wide aspect ratio. Traction was a consideration. As the tires wore down and got stickier it was harder to turn. In the off season we put tape on the front tires to reduce traction to make turning easier.
In the past we had long aspect ration bots with skid steer. In 2004,5 our tires were about 10-12" OD. They took lots of power to turn and were not " precise". On a high center of gravity machine there was quite a bit of bucking/tipping. We started out this way in 2006 and ended up with 2 omni wheels before we shipped.
On a low CG bot the long aspect ratio configuration was OK. In the future we'd most likely go with the 6 or 8 wheel design.
Jay
Unread 23-12-2010, 11:49
Related thread about mounting sprockets, etc.
http://www.chiefdelphi.com/forums/sh...ad.php?t=88066
Unread 26-12-2010, 15:30
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Rookie Year: 2000
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
We've used pneumatic tires in 2002 and several other years but those were the best tires/wheels yet. They were small so there was little bounce, yet great traction. The fact that they were pneumatic also lent itself to correct for leaning and imperfections in the carpeted surface--four wheels were always gripping. That was the year when 71 Hammond Beatty had the crawler which dragged the two goals with the opponents kicking and fighting to the other side of the field--so traction was paramount.
Here's a link. At the time everyone made their own hub mounting plates. The following year, FIRST came out with hubs in the KOP. Two large fender washers with the holes bored out with the use of standoffs sandwiched in between worked well for many teams.
http://www.skywaywheels.com/products/caster/index.html
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 17-12-2010, 03:32
Yalib Yalib is offline
FRC #2630 (Thunderbolts)
Rookie Year: 2011
Yalib is on a distinguished road
Originally Posted by Joe Ross View Post
50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary.
I'm also a member of 2630,
We checked out the mcmaster wheel and it looks really good, Do you know if this wheel has a tenon slot?
  #15   Spotlight this post!
Unread 17-12-2010, 11:13
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
You mean a keyway? Not stock--you'll have to modify the hub. It's designed to be used as a caster (unpowered), so any powered use needs modification.
Past teams:
Where can I find gears? vivek16 Technical Discussion 16 13-05-2008 08:38
where can I find it? kDude Control System 3 22-01-2008 17:50
Pro/E...Where can I find it? vedas Technical Discussion 4 21-04-2004 23:45
