Go to Post I don't care what the team numbers said, on Friday there were no rookies there. - Taylor [more]
Unread 19-12-2010, 01:54
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
Sprockets as Chain Tensioners?
Hey everyone
I've noticed that a lot of teams place free-spinning sprockets in the middle of their chaining, and I assume that this is for chain tensioning. If that is the case, then is it actually a good method for tensioning chain?
Thanks,
Michael
Team 955
Raiderbot
Unread 19-12-2010, 07:16
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: Sprockets as Chain Tensioners?
That's typically how we do it. Last season we had the idler sproket mounted on a short section of c-channel with two bolts holding it to the frame. When we needed to adjust the tension, we put a washer under the c-channel to lift it up a bit.
Unread 19-12-2010, 07:31
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I think what you are referring to are sprockets that just 'suspend' between the upper and lower chains, some refer to them as "majic sprockets". The sprocket is sized to be a slightly higher tooth count (diameter) than the sprockets on the shafts.
We have used them and in some places they work well. They float between the upper and lower chains, and will move back and forth a bit while the chain is running. I think they work best when you can use a small diameter sprocket for the tensioning (2 to 2-1/2 inches) and shorter runs of chain (12" shaft to shaft).
We used them with about a 4" diameter and in a 24" span, and due to the flexibility of that length of chain and the diameters, they would occasionally pop loose if we were hit hard.
AndyMark sells some very simple tentioners that also work well. They were actually designed by a student on an FRC team (from California I think). Here is a link to the product page.
http://www.andymark.com/ProductDetai...Code=am%2D0286
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 19-12-2010, 09:04
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
We call them Chinese stars......they work great in a pinch, but I typically shy away from designing them in. They can be tricky.
Mcmaster sells a flexible style, way over-priced.....McMaster 5896k1. We usually just stick an AM sprocket in there and let it go.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 19-12-2010, 09:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by ajlapp View Post
They can be tricky.
Could you elaborate on that a little bit? Tricky how?
Unread 19-12-2010, 10:44
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
We've used them on many drive systems as tensioners with #25 chain. However, we also use them to drive encoders to keep track of the robot during autonomous mode on a live axle (dual purpose device) with shims to adjust tension.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 19-12-2010, 10:59
Rookie Year: 1942
Look at post #18 in this thread. Is this what you are referring to?
http://www.chiefdelphi.com/forums/sh...t=43750&page=2
Or, are you talking about placing a sprocket on some type of bracket and using that as a tensioner?
Chris Fultz
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
We've used them before with 25p roller chain, and they work great. After you first install them you need to keep constantly adjusting them every match or so during your first competition or so. Once the roller chain finished stretching, we left it in the same spot and never really needed to adjust it.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 19-12-2010, 11:35
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Sprockets tend to be heavy. While a sprocket on a tensioned arm or inserted between the chains can make a good tensioner, you pay the weight price. There are other less weighty ways to tension your chain, though the sprocket mounted on an arm makes a great one.
Unread 19-12-2010, 11:48
AKA: Anthony Lapp
Rookie Year: 1996
Chris captured some of the problems above....
If you deploy a floating star tensioner on a long run of chain, the system tends to "slap" back and forth under load. Hard to explain without a diagram. This action can eventually through the tensioner.....especially if the chain tries to twist at all.
The point is, if you can design to the proper center distance and plan for a tensioning device, say a bolt or cam, I believe it will be more robust for competition.
We have used these in the past many times, but always as a fix, never as the planned way.
Anthony Lapp
RobotOpen
Unread 19-12-2010, 12:41
AKA: Michael Groom
Thanks!
Team 955
Raiderbot
Unread 19-12-2010, 13:01
AKA: Anthony Lapp
Rookie Year: 1996
You could try a cam....see the picture below. Each cam has a 1/4" shoulder bolt that acts as an axle. The bolt is drilled off center. You twist the cam into the desired position then tighten a set screw....this drives the aluminum cam up into the bolt and locks everything down.
As the delrin wears you can adjust the tension or replace the bushing altogether.
Anthony Lapp
RobotOpen
Unread 20-12-2010, 18:06
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
Team Role: Leadership
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
my team used some larger zipties to tighten up our chain and they worked very well.
AndyMark Chain Tensioners CodyHarris Kit & Additional Hardware 2 28-03-2010 13:29
pic: Integrated, easy to use chain tensioners Jon Stratis Extra Discussion 9 21-02-2010 22:37
pic: Sliding Wheel Chain Tensioners Ice Berg Extra Discussion 18 22-04-2009 00:45
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
