Go to Post you know your team has respect from teachers when classes start waving projects during build season saying you get full credit if the robot ships. - Peck [more]
Unread 20-12-2010, 18:25
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
pic: Klein Bottle in Solid Works.
Unread 20-12-2010, 18:29
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Re: pic: Klein Bottle in Solid Works.
For real fun output it as a .stl file and see if you can get a rapid prototyping house to make one via SLA. It looks like it should build OK without much support structure.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 20-12-2010, 18:35
Chris is me's Avatar
AKA: Pinecone
Looks good, though I'm curious why you need to learn surfacing commands to work with lexan.
Unread 20-12-2010, 21:23
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
I wonder as well? Unless you have access to injection molding equipment I dont really see the use (although it would be very cool). Either way surface modeling is definitely a good skill to have as more and more things are being made by molding now.
Mentor 2415
Unread 21-12-2010, 20:59
AKA: Isaak
Team Role: CAD
the purpose to learning surfacing commands is to test modeling of corrugated lexan. We also have a gizmo that is sort of like a vacuum mold but uses large sheets of lexan and a plaster cast. all of this could have been done with solids, but an excuse to get better at CAD is always a good thing.
Unread 28-12-2010, 11:31
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Beautiful model and congratulations for taking on advanced SolidWorks modeling skills with surfaces. Surfaces are heavily used in the consumer product industry and in the outside shells of a more humanoid-type robot. Creating surfaces to be used as cutting plane is also an important skill in machining.
Using advanced features like sweep and loft with surfaces are illustrated in creating this butterfly http://blogs.solidworks.com/teacher/...butterfly.html
You can download the model. There is also video instruction on how it was created. Photoview 360 was used for the rendering http://blogs.solidworks.com/teacher/...oview-360.html
Marie
Solid Works Trouble kyle601630 SolidWorks 6 11-12-2010 12:08
Solid Works availability betsy888 SolidWorks 4 15-02-2010 17:54
newb at solid works. Chino 237 Inventor 6 13-10-2004 22:22
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
Solid Works 157#1Driver Inventor 0 21-04-2002 20:17
