Go to Post It is a little known fact that Team 1114 is actually "General Motors Canada and Hogwarts Academy" The whole Niagara FIRST thing is just a cover to keep the magic arts concealed from us muggles. - dtengineering [more]
Unread 21-12-2010, 20:52
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
254 Gearbox Analysis
Always great innovators, the Cheesy Poofs did not disappoint last year. Their 2010 effort was an outstanding one, and I've decided to put togther a case study and present it to my team in preparation for the upcoming season. In doing I realized just how great their gearbox was and thought I'd share and also try to collaboratively reverse engineer it.
Basic Overview
http://www.team254.com/media/photos/...e=orig&id=4247
They advertise this as a two speed transmission, running at 5 and 15 fps, which strangely has two shifting cylinders. It was part of an 8-wheel drive robot, with one wheel per side direct drive and three more driven by the pictured sprockets. The truly unique feature is the Power Take Off (PTO) that they used to power their lift mechanism. Under normal operation the gearboxes would power the drivetrain. Under PTO mode those motors were repurposed for lifting the robot. Very successfully I might add. Check out the end of this clip:
http://www.thebluealliance.net/tbatv/match/2010sj_f1m1
I wasn't able to uncover any great pics of the PTO mechanism, but this side view clearly shows a pneumatic cylinder that would appear to be the toggle mechanism.
http://www.team254.com/media/photos/...e=orig&id=3139
EDIT: This appears to be a false assumption
You can see an upper sprocket in this pic, a top view. This is presumably used to drive a chain that powered their lifter. There does not appear to be a dog gear so I'm unsure how they so reliably transferred power from one output shaft to another. Anybody know?
http://www.team254.com/media/photos/...e=orig&id=4249
Also, what is this clutch for? It looks like a small slip clutch, maybe used to limit torque?
EDIT: This is a different gearbox from the pictures above. This was used to power the roller/ball collector mechanism.
http://www.team254.com/media/photos/...e=orig&id=4251
Unread 21-12-2010, 21:19
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Rookie Year: 2007
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
Re: 254 Gearbox Analysis
I believe the last picture is the setup for their ball accumulator. A lot of teams last year that had pinch roller setups used some sort of clutch to keep constant pressure on an acquired ball and not burn out a motor.
"More power 'till it breaks or you win."
- Keith Carey
Unread 21-12-2010, 21:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
This may be a stupid question, but did you try going straight to the source with any specific questions you had? One of the great things about FIRST is most teams are willing to share if you're willing to ask.
Unread 21-12-2010, 22:00
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
I was able to learn anything I wanted about the gearbox by just asking them in Atlanta. Reverse engineering is fun, but it's easier to learn about the decisions that went into these robots from the source, really.
Unread 21-12-2010, 22:32
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Having asked 254 direct questions myself, I am sure they would more than glad to explain this mechanism to you! They are an amazing team, and always create a dominating robot because of designs like this.
Unread 21-12-2010, 23:36
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
I think the last photo is a release for a ratchet system......this would stop the lift mechanism from back driving.
The first photo shows the two separate dog shifters. I believe those are three position air cylinders.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 22-12-2010, 03:47
craigboez's Avatar
Mechanical Engineer
I'm sure all the members of 254 are very helpful, I just don't happen to know any of them. This public forum that they most likely check frequently seemed like a good place to start a discussion. Plus then everyone gets to benefit from this, not just me.
After looking at this further, I think a few of my initial assumptions were incorrect. It would appear that the "lower" dog plays the role of speed changer and the "upper" dog serves to engage or disengage the PTO. At first I thought both of those were part of the speed changing equipment. That accounts for two of the three pneumatic cylinders. I am still unsure of what the third, larger pneumatic cylinder is used for.
I'd agree. It looks to be a Bimba FOP style cylinder. Reference page 2.35 of this PDF: http://bimba.com/pdf/catalogs/FL_FlatCylinders.pdf
I'd agree. This bot has several gearboxes and they all look alike, so I confused the ball collector gearbox with the drivetrain/PTO gearbox.
Unread 22-12-2010, 03:51
NickE's Avatar
NickE NickE is offline
_
FRC #0254 (The Cheesy Poofs)
NickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond repute
Craigboez,
I'm Nick and I'm the design/build captain from Team 254. Thanks for the kind words about our design and we'd be thrilled to talk to you more about it. Everything you've posted about our robot seems accurate but if you have any questions, feel free to contact us and we'll try our best to answer them. My email is on our team website or you can contact me via PM or in this thread.
Nick
Unread 22-12-2010, 09:17
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
I'm pretty sure the 3rd cylinder you are referring to is the release for the pawl on their ratchet system used in the PTO.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
pic: 254/968 Gearbox - Destructive Testing Results Travis Covington Technical Discussion 23 19-06-2007 14:58
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
CFD Analysis daramana Inventor 0 21-01-2005 00:01
Analysis of pictures archiver 2000 35 23-06-2002 21:57
