Ping ok, but still no Comms
Has anybody seen (and solved) the conundrum whereby you can wirelessly ping every part of the control system, including the cRio, yet the DS shows no robot communications?
I remember seeing a previous post that that was all the DS did to check comm status. |
Re: Ping ok, but still no Comms
I think pings are only used in the diagnostics screen, but the big section with "Robot Communications" means it is actively talking to the FRC_NetworkCommunication task on the cRIO.
Are you running NetConsole? Can you check if it is posting any errors? |
Strangely enough, it began working after multiple reboots and resets.....so I'm still trying to figure out why!
I think any trouble I've had with that has to do with multiple network interfaces; having both ethernet and wireless enabled, and the DS doesn't know which to choose.
The strange thing is the DS would only connect to the cRio if I had the wireless turned ON in my laptop!
Are you connecting through ethernet or through wireless?
Wireless
That sounds like the issue then.
You may have to disabled your ethernet port (or have it disconnected) in order for your DS to connect. |
But I was using the ethernet port to connect to the router. While I could ping the cRio with the wireless off, I needed to turn it back on for the DS to see the robot. Very strange!
#10
That means your DS was configured to use your wireless interface.
I don't recall how to switch it, but disabling your wireless might work. (If you're using Windows XP, this is done in the Network Interfaces part of the Control Panel; turning your wireless off on your laptop does not disable the interface.) |
#11
On last year's DS, the communications thread would lock in the DS IP address and the robot would need to be rebooted in order to change the DS to a new IP. Changing from wired to wireless NIC would typically use a new IP.
Greg McKaskle |
| Can ping CRIO and bridge, but DS shows no comm and no code | Green2 | FRC Control System | 3 | 22-01-2010 23:55 |
| Camera locks on but it still off | dpick1055 | Programming | 3 | 18-02-2007 13:11 |
| Not quite an animation, but still... | Mazin | 3D Animation and Competition | 7 | 13-06-2006 22:25 |
| pic: Tired but still fun at 3 a.m. on ship day! | CD47-Bot | Extra Discussion | 6 | 27-02-2004 11:52 |
| Team 108 Finishes, but is still confuzed | Specialagentjim | 3D Animation and Competition | 2 | 20-03-2002 19:33 |
