Go to Post There is nothing that compares to the smell of burning flesh, especially when it is your own. - Al Skierkiewicz [more]
Unread 29-12-2010, 15:27
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
jars: creating and adding
I am working on packaging up the ZomB Dashboard bindings for java, and I have two questions: How do you create a jar as a library? and How do you add it to a project so it can use the jar?
When I build a project, it produces a jar file in suit/project_1.0.0.jar. Is this a good jar file? When I drop it on a project, or add it in the ant classpath, it produces errors:
Code:
init:
No to.jar.file specified.
Using "suite\RobotTemplate_1.0.0.jar"
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\build
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\suite
Deleting directory C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\j2meclasses
clean:
Created dir: C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\build
Compiling 1 source file to C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\build
C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\src\edu\wpi\first\wpilibj\templates\RobotTemplate.java:10: package org.thecatattack.System451.Communication.Dashboard does not exist
import org.thecatattack.System451.Communication.Dashboard.*;
C:\Documents and Settings\***\My Documents\NetBeansProjects\RobotTemplate\src\edu\wpi\first\wpilibj\templates\RobotTemplate.java:22: cannot find symbol
symbol  : class ZomBDashboard
location: class edu.wpi.first.wpilibj.templates.RobotTemplate
        ZomBDashboard zomB = ZomBDashboard.getInstance(ZomBModes.TCP, "10.4.51.5");
symbol  : variable ZomBModes
symbol  : variable ZomBDashboard
4 errors
C:\Documents and Settings\***\sunspotfrcsdk\ant\compile.xml:48: Compile failed; see the compiler error output for details.
BUILD FAILED (total time: 18 seconds)
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
AndyMark Wheels- adding sprockets, bolts, and such Bryan Herbst SolidWorks 14 31-05-2008 22:01
Adding hinges and a door lock to the crate Mikhail_Pham Technical Discussion 1 18-02-2008 17:47
Creating and selling parts. Billfred General Forum 30 21-07-2004 00:18
Adding Sound Effects and Music to an Animation Hailfire 3D Animation and Competition 19 26-01-2004 23:10
Adding stickers and Cosmetic detail at competition archiver 2001 3 24-06-2002 01:29
