pic: Super Light Chassis System
Re: pic: Super Light Chassis System
Very interesting. Looks like it could be extremely useful, and it does look extremely light! A few questions:
How much does it weigh? What are the dimensions? |
The narrow bot configuration is 37" by 22.5". The wide bot configuration is 27" by 32.5". Super Light product page. |
It looks very simple and straight forward. I like that it is reconfigurable into a variety of configurations with little effort.
My only concern is it's ability to resist racking during the rigors of competition. Might I suggest that once it is assembled in it's final configuration and aligned and squared that the joints be welded. A bit of the hardware could then be removed and a bit of weight could be saved. |
Very impressive. I have seen many of your systems before, and the more I look into them, the more I am impressed. Does your team design make all of these products? And have you ever configured this system so it was completely gear-driven? It would add a little weight, but I think you would save on the hassles of chain.
Great design, and excellent work. |
I'm assuming the "hassles of chain" you're referring to would be proper tensioning and alignment, which are more or less resolved with by the super light chassis system.
Disclaimer: Our company is independent of FIRST Robotics and is not associated with any team. Quote:
Very nice. The 1 by 2 bar kind of reminds me of the Poof's chassis. With some welds and a bellypan I bet it would be really stiff too.
It's definitely drawn a lot of inspiration from the classic west coast drive of teams like 254/60/968.
#10
We have never tried direct drive, though Andymark has a system that works well....and I have admired team 25 for years. Every design choice has it's merits!
The name Team 221 LLC. has turned out to be a poor choice. It was supposed to be a reference to our inolvement with FIRST and to the fact that I once was the leader of FRC221, the number was retiredin 2001. At the time it seemed a fitting moniker for a company that got it's start developing products for competitive robotics teams. We now refer to ourselves as 221 Robotics Systems. This naming confusion is only a problem when we participate in FIRST events. ![]() |
#12
With proper alignment and tensioning, which is pretty easy, chain failure in #25 chain is a complete non-issue. |
#14
Do you really need two frame rails to create a geared system? I would imagine that if you created it well enough you could modify this very system so it could be a geared system. If I am wrong please let me know. I am very curious, and obviously ignorant. ![]() |
#15
Ground clearance and low wheel size is another big thing with chained systems.
With a gear drive, you want as few gears as possible or else your weight and efficiency really starts to add up. To accomplish this, you'll need big gears (several inches in diameter), which brings the gears rather low to the ground unless you also use very large wheels (8" or more). Here's a diagram of team 25's drive (probably similar to 103's): ![]() The design works because of the very large wheels to accompany the large gears. While great for climbing, large wheels inherently weigh more than small ones and combined with the multiple gears and drive shafts adds to the weight considerably. With a sprocket drive, you can run relatively small sprockets on relatively smaller wheels. ![]() Here the sprockets for 6 inch wheels are only about 2.5 inches in diameter. This keeps the chain clear of the floor while reducing sprocket weight. The 6 inch wheels in turn are much smaller, lowering weight further. |
| pic: super bimba ultra | efoote868 | Extra Discussion | 16 | 05-02-2008 11:43 |
| Green Light For Vision System Angle & Distance | StorminNormin1 | Technical Discussion | 2 | 04-02-2007 15:47 |
| pic: Super Brandon | Rohith Surampudi | Extra Discussion | 4 | 17-06-2006 19:41 |
| pic: Super LAN | Barry Bonzack | Extra Discussion | 10 | 18-04-2005 20:33 |
| pic: super scooter | CD47-Bot | Extra Discussion | 12 | 05-08-2004 18:40 |
