Re: 6WD vs 8WD
However, consider that the driving force (i.e. output torque of the motors) decreases with speed. At some speed the motors will lack the torque required to spin the wheels, barring extreme cases. At that point, the situation will become the F=ma situation we all know and love and the lighter robot will be able to accelerate faster. Another interesting tidbit is that the wheels' coefficient of friction may not be constant, but rather vary with contact pressure. Assuming that the coefficient of friction is constant the heavy and light robots will accelerate at the same rate in a friction-limited case. However, if the tread/playing surface is sensitive to contact pressure then the lighter robot will have the advantage, all else being equal. Also note that a drive-train does not require power to break traction, but rather requires torque, specifically torque on the drive wheels. |
Re: 6WD vs 8WD
Re: 6WD vs 8WD
mass = 40.82 kg force = 320.27 N acelleration = 320.27N / 40.82 kg = 7.846 m/s2 = 25.74 ft/s2 Given that no robots can get up to 25.74 ft/s in a single second (or at all for that matter), the acceleration is clearly limited by gearing/motors, not the traction of the wheels. So in this case 67 would in fact accelerate about at about 4/3 the rate of the 120 robots that they compete against. |
Re: 6WD vs 8WD
Another point is that radial wheel [drivetrain] acceleration and linear robot acceleration are two different matters, though often linked together in FRC scenarios. |
Re: 6WD vs 8WD
i think that 6wd is a more agile drivtrain, it turns a bit easier, and is also a bit faster accelerating, due to less stuff needing to be accelerated. however an 8wd is generally beefier, more precise. i think they tend to be a bit slower turning, but also harder to turn. i noticed this year that we had little difficulty spinning some top teams with 6 wheel tank. however any 8wd teams we attempted to defend were much more difficult to knock of course, notably 610 and 691. if it were a game like overdrive, or this year, where speed kills, 6wd would probably perform slightly better. if it were a game like 2010 or aim high, i might choose 8wd due to the way it is less likely to be pushed.
Re: 6WD vs 8WD
Look carefully at how an 8wd with the center two wheels dropped is built. Specifically their wheel base. Then look at 6wd. Then apply that thought to this white paper. Does the math support your hypothesis? If not what other factors could be coming into play? |
Re: 6WD vs 8WD
The ride height was controlled by the claw, and is automated (more drop when turning, less when not). The driver must request a bump-cross, but when not bump-crossing, it handles ride height on its own. From Danial Ernst's pictures from the State Championship: ![]() The rear chassis (the part we attach the bot-bottoms to) is mobile, pivoting around the rear axle (omni wheels), and containing the drive motors (4 CIM + AM shifters), and most of the control system. The gearbox is chained directly to the middle and rear wheels, and the rear wheels are chained to the front wheels via two jack shafts per side (over the top above where the chassis floats). In software, the normal claw movement (including the bump-crossing and flat centered positions) is handled with the claw axis pot, and center dropping is handled by a string pot in the chassis which measures drop. |
Re: 6WD vs 8WD
So, I was very inspired by some of the physics guys up above, and have a challenge:
Assume 16m dash (approx. 54 feet- robot length), and COF of 1.0. Also assume a 4 cim power-train at 300 Watts/CIM. What weight is your bot so that you are just barely traction limited the moment you strike the other wall? Is this less than 4 cims & a battery? |
Re: 6WD vs 8WD
PT = 4PCIM P = 1200 watts (~80 - 95 % efficient depending on number of gears, transmission, and other variables) Ff = mgµ = m*9.8*1 = 9.8m Work = Force * Distance = 9.8m * 16 = 156.8*m time = Work / Power = 156.8*m / (between 960 and 1140) watts = between .138*m and .163*m seconds so to solve for mass (in kg) it would work out to between 6.135 * t to 7.246 * t depending on the efficiency. Of course, this all assumes that the robot would be constantly accelerating at the maximum possible value (no slipping/static friction) and that the robot would be able to keep getting faster and faster, but I'm pretty sure it would be impossible to gear 4 cims without a transmission such that they provided exactly maximum static frictional force and still could reach rotational speeds that would allow it to continue accelerating...would probably need really really small wheels, but not too sure about that one. |
#10
Re: 6WD vs 8WD
i personally like 6 wheel it is lighter and well tested. as a matter of fact we built a 6wd drivetrain this off season and it preforms excellent, very maneuverable and fast. video form testing this afternoon: http://www.youtube.com/watch?v=KwOr-Mpl8DA
#11
Re: 6WD vs 8WD
Re: 6WD vs 8WD
Now that I think about it, the size of the wheel really wouldn't matter...
Although I would usually love to sit down and work out the rest if this problem, at this point I feel like that would be selfish of me because I'm sure my team would rather have me well rested for kickoff which outweighs my own personal satisfaction of solving the problem |
#13
Re: 6WD vs 8WD
The final speed, as well as the acceleration are functions of the angular velocity and acceleration of the drive shaft (respectively), as well as the wheel radius.
Think about a wheel with radius = r and a driveshaft with some torque T. We then sum the torques about the center of the wheel and get Fa*r < Fsfmax*r (theta is ninety so it goes away sin(90)=1). Cancel the r, plug in uFn for Fsfmax, and you have your max Fa to not slip. Use T = F * rsin(theta) and you get the max torque from the driveshaft to be traction limited. From there it's just some basic ratios back to the torque output of the motor and that ratio is your desired gear ratio. Now, this assumes that you have a perfectly efficient gearing system, and that your wheel has no mass and therefore no moment of inertia to slow the acceleration, but it gets you close. For speed based, do the same basic thing only with rpm instead of torque. |
#14
Re: 6WD vs 8WD
@Adam: I misinterpreted that post as saying that in order to be traction limited you needed to have a free speed of 27 feet per second or something. My bad.
#15
Re: 6WD vs 8WD
1) How long does it take to go 16m when you are traction-limited the whole way? Ffriction = 1.0 (CoF) * Wrobot (because Ff = mu * Fnormal) a = Ffriction / Mrobot (because F=m*a, so a=F/m) a = G (because Wrobot/Mrobot = G, gravity) D = .5 * a * t^2 t = sqrt(16 m * 2 / G ) t = 1.81 seconds 2) How fast are you going just before you hit the wall? v = a * t v = G * 1.8 seconds v = 17.7 m/s 3) At this ultimate speed, we are barely traction limited, so: P = F * speed (1 Watt = 1 N * m/s) F = Wrobot speed = v = 17.7 m/s 1200W = Wrobot * 17.7 m/s Wrobot = 67.8 N = 15.2 lbs So yes, less than 4 CIMs and one battery. |
| What does it take 6WD/8WD to be successful? | TEE | Technical Discussion | 26 | 06-05-2010 08:30 |
| pic: Rastogi 8wd Iteration 1.2 | Akash Rastogi | Extra Discussion | 56 | 05-05-2010 15:16 |
| pic: Sheetmetal 8wd | Akash Rastogi | Extra Discussion | 16 | 02-05-2010 15:38 |
| pic: Concept 8wd Drivetrain | sdcantrell56 | Technical Discussion | 77 | 25-11-2008 23:05 |
| 8WD drivetrain? | David Sherman | Technical Discussion | 16 | 09-04-2006 17:32 |
