Go to Post No need to apologize, you didn't do anything wrong. your just learning. thats what the forums are for. please keep them coming. - Tytus Gerrish [more]
Unread 05-01-2011, 18:22
ErikRantapaa ErikRantapaa is offline
FRC #2532 (Flash Power)
Rookie Year: 2010
ErikRantapaa is an unknown quantity at this point
VIs stop running after two seconds
On one laptop I am having a problem with VI's terminating a couple of seconds after deployment.
For instance, when running the Analog Input example I can deploy the VI, and it appears to run, but then it just stops after a couple of seconds. No error dialog box comes up - apparently the VI goes from running mode to stopped mode.
Other symptoms:
- the status led on the cRIO will start to intermittently blink three times (i.e. blink-blink-blink, pause, blink-blink-blink, pause, ...)
- the driver station indicates there is no communication with the cRIO
- if I single step through the code, I never make it through one iteration of the inner while loop; the top branch of the OR operator connected to the stop condition becomes true right away; if I remember the VI correctly, this is an error condition, but I haven't been able to figure out what the error is.
However, I don't have these problems on another laptop. The main difference between the two is that on the one that works I installed Windows 7 myself and the one that doesn't has a factory installed Windows 7.
Any ideas of what the problem is? Is there more I can do to diagnose the problem?
Thanks!
Problem with breakout box after update two Sarah348 Control System 1 12-02-2010 12:18
TeleOp Init/Stop vs. Auton-Iterative Init/Stop Ziaholic NI LabVIEW 11 07-02-2010 22:19
Any teams build two robots to practice with after build season. (6 weeks) GVDrummer General Forum 42 24-01-2008 21:34
pic: 166 Before and After: All in Two Hours Dan Petrovic Extra Discussion 3 30-06-2006 16:43
Stop The "Lesser of two evils" MattK Chit-Chat 8 07-08-2004 23:31
