Go to Post You can't observe things that aren't seen or reported. - Andrew Schreiber [more]
Unread 06-01-2011, 18:26
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
4" vs. 6" vs. 8" wheels. Advantages?
I've searched and I really didn't find any discussions that directly answer these questions. If you know of a posting or white paper that addresses these questions, can you please post a link to it, otherwise, what are your thoughts, and why?
I've read through several white papers, but none seem to address these specific questions.
If gearing was appropriately matched, what are the advantages and disadvantages of the various diameters of wheels? Does the width of the wheel really matter that much?
EDIT: This is as much for general consumption as it is for my education.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 06-01-2011, 18:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: 4" vs. 6" vs. 8" wheels. Advantages?
As a general thing, obstacle traversing is better with a larger wheel (larger wheel, larger obstacle). However, larger wheels can easily be more weight, and a smaller wheel can be made to climb as effectively as a large one. Pick your poison; I'm not quite sure whether there's enough difference between a 6" and 8" or between a 4" and a 6" to make it worthwhile. You only get about an extra inch of vertical climbing ability. 4" to 8", probably enough to make it worthwhile.
On width, ideal physics says no difference, while reality says wider is better. I'll let the idealists and the realists argue that one out, preferably by testing.
Gearing matched: Given that the gearing is matched to give the same robot speed, a smaller wheel will tend to need a smaller reduction (less weight) to go as fast as a larger wheel. (Smaller reduction = higher rotational speed, for those that might be confused.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 06-01-2011, 18:43
billbo911's Avatar
OK, so smaller wheels have a distinct advantage for lowering the CG of the robot and maybe reducing the weight a bit, but also reduce ground clearance if it is needed. Larger wheels allow you to traverse a larger step change in the driving surface, but not much advantage on a ramp change.
Good stuff. What else?
Unread 06-01-2011, 18:50
Chris is me's Avatar
AKA: Pinecone
If you're going to assert reality contradicts physics, please at least cite a source of test results or other evidence. Statements of fact without backing like this are how misconceptions are made.
Anyway, there are a lot of reasons to like smaller wheels. The wheels themselves weigh less, and less of a reduction is needed to achieve the same output properties as a larger wheel. The primary drawback is that smaller wheels require more effort to climb obstacles with - a smaller wheel inherently has lower potential ground clearance than a larger wheel. With proper design this can be worked around - many teams climbed the bump this year with 4" wheels and the bump was a rather aggressive obstacle.
Unread 06-01-2011, 18:55
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
There is a team working on testing this. As such, there are no definitive results yet. It's quite possible that theory and reality agree. But there have been some CD discussions on this topic over the years, which taken together indicate that there is some disparity, due mostly to rubber interacting closely with carpet to give a slight but noticeable increase in traction on a wider wheel.
Remember: Ideal physics tend to take place on a surface with uniform friction (possibly no friction) and in a vacuum unless otherwise specified. There are very few places that have both. Because that sort of place is rare, especially when Murphy is around (or at a robotics competition), reality tends to win over physics by emphasizing those slight differences.
Past teams:
Unread 06-01-2011, 18:58
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
"F= uN" is physics
"u = constant" is an engineering approximation... which may or may not be a good approximation depending on material properties.
Unread 06-01-2011, 19:04
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...ht=tread+width I will point everyone to that thread. There are a couple others.
I also distinctly recall Andy Baker making some comments on this. Where they did some tests and found that a wider tread DOES have more grip on carpet.
Suffice to say this debate has been going on for as long as most of us have been around these boards.
I also want to point out an earlier thread on this http://www.chiefdelphi.com/forums/sh...ad.php?t=84980
(If I screwed up some of these links and made them point to the same place someone let me know, I'm sort of out of it today)
Unread 06-01-2011, 19:30
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
Rookie Year: 2007
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Wider tread provides absolutely no benefit. When the surfaces are hard, uniform, and flat (Lunacy)
A wider tread does increase the amount of gripping ability when you are talking about carpet though. Think of carpet wheels kinda like Velcro, when you drive a carpet wheel over carpet, some amount of interweaving occurs, resulting in some amount of grip based on contact area.
Whether or not the amount of increased grip is usable is still up in the air, but I am betting that it would increase grip a small amount.
Unread 06-01-2011, 19:42
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Unfortunately, in the case of polymers, this is not a misconception. On a microscopic level, polymer-based materials (such as the rubber on wheel treads) have "knobs" that protrude and grab on to the microscopic "hooks" of fibrous materials (such as carpet). For this reason, increasing the contact pad increases the number of "knob" to "hook" interactions, which in turn provides an increase of traction. Idealistic entry-level physics states that F=uN, and so as long as the normal force and coefficient of friction remain the same, (it is commonplace to assume that surface area has no affect on the coefficient for basic physics because the other equations are far to complex for classroom labs) no change in frictional force will occur, regardless of the surface area.
Think of it like Velcro. What's harder to pull straight off, one hook grabbing on to one loop, or one inch of hooks on one inch of loops.
"F= uN" is physics
To build on what Ether said, this is only a rough approximation of the resistant force felt by an object, and lumps together everything from microscopic surface roughness to how deep one object sinks into another (e.g. a marble on carpet). There are, however, many other equations that these factors into account.
Sorry if this repeats any of the information on the linked threads, it's just nice to have all the important information in one place.
EDIT:
big1boom got to it first
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 06-01-2011, 20:06
AKA: Pinecone
Do any of you have measured data of how this phenomena applies to an FRC application? Anyone?
Do any of you whom are convinced about this fact with long explanations know how much surface area comes into play? Numbers and rates, not "a little" or "a lot".
Unread 06-01-2011, 20:10
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Do any of you have data of how this phenomena applies to an FRC application? Anyone?
Chris, see the links that Andrew gave.
Wider wheels (or tank treads) = larger contact patch. Larger contact patch = more grip than smaller contact patch. More grip = more traction for the same surface. Therefore, more drivetrain contact patch = more traction, under carpet conditions.
Past teams:
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
234 did some testing recently, I imagine they're planning on publishing the results.
My wager is the effect is larger than people would think.
Unread 06-01-2011, 20:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If wider wheels give more grip, would larger diameter wheels also, because they increase the length of the contact patch?
Unread 06-01-2011, 20:16
AdamHeard's Avatar
Lead Mentor
For roughtop tread, I am going to make an assumption that smaller diameter wheels get more grip as they form more of a sharp cleat than larger diameter wheels do. This cleat is a better shape for interlocking with the rows of carpet fibers.
Making it wider still retains this shape, but increases the width of the cleat.
This is purely based on the anecdotal evidence of our 2008 krab drive running 2" wide wheels.
  #15   Spotlight this post!
Unread 06-01-2011, 20:15
AKA: Pinecone
Yes, I understand that more = more, that's not what I was asking at all.
My point was that accepting a statement as truth without understanding the magnitude of the effect, or knowing how much the effect applies, is not a good idea. Especially when "conventional wisdom" has all of those things.
It seems like a lot of people are parroting back stuff they heard from some guy instead of relying on observations and data. How is that good engineering?
Analog inputs not "working" — I only detect "noise" keehun Programming 11 31-12-2008 19:01
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
