Go to Post We are here to both learn and teach. - Steve W [more]
Unread 06-01-2011, 21:50
PortugazD.Ace's Avatar
PortugazD.Ace PortugazD.Ace is offline
AKA: Timothy Gonzales
FRC #1165 (Team Paradise)
Team Role: Student
PortugazD.Ace is an unknown quantity at this point
Cypress PSoC system
Has anyone tried to use the cypress PSoC for controlling sensors? if so, how did it work?
Latin:
"Murmure ventus erit parere Tempestatem"
"Noctu teneris vinculis
Nocte illa vincula adimuntur"
Unread 06-01-2011, 22:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Cypress PSoC system
I don't understand the question. The way I think of things, "reading sensors" and "controlling actuators" make sense, but "controlling sensors" is a strange concept. Can you explain what you mean by it?
Unread 06-01-2011, 23:47
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
You mean using the sensors on the PSoC as a driver interface, for controlling the robot?
-- Marshal Horn
Unread 07-01-2011, 15:54
Team Role: Student
no. I mean like getting information about the surrounding environment to help the robot navigate during autonimous mode(Sorry if I misspelled something.)
Latin:
Unread 07-01-2011, 16:26
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Well, let's see. What information can you get from the PSoC, assuming you're using analog module on the cRIO for your analog inputs?
accelerometer?
I don't think the proximity sensor is very useful.
I suppose you could write a program to use the accelerometer as a tilt sensor. Actually, you might be able to have it acquire data from the other accelerometer over I2C, and make a 2D gyro. That would sure be cool.
Other than that, how would it be useful on your robot? (Oh, and you could use it for parallax SONAR, which uses the same pin as DI and DO; something you can't do on the digital sidecar without performance degradation)
-- Marshal Horn
Unread 07-01-2011, 17:24
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
If the PSoC is being used connected to the classmate/DS, you will not be allowed to use it to help your robot navigate in autonomous (This is very likely a rule this year, and is also enforced in the FMS).
If you are talking about using it on the robot, you're probably better off just connecting the sensor to the cRIO or the Jaguars (if using CAN), unless you need the PSoC to offload some calculations from the cRIO.
Analog Out on the Cypress PSoC (enhanced modeO gokul Programming 5 23-02-2010 14:05
LEDs on the Cypress PSoC mcbean Programming 4 21-02-2010 15:55
Cypress Programmable System-on-chip Solution scottbot95 Control System 3 08-02-2010 20:13
Cypress PSoc Programmer Port Selection problem Steven_585 FRC Control System 2 23-01-2010 23:06
Cypress Programmable System-On-Chip Solution? 1jbinder Electrical 5 12-01-2010 22:13
