Go to Post Dave Lavery was right... all we had to do was type in "attack old lady" and when we started up our robot it did. - Human Player [more]
Unread 07-01-2011, 00:59
Jedward45 Jedward45 is offline
FRC #2220
Jedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant future
pic: Team 2220's Swerve Drive Module
Unread 07-01-2011, 01:03
Chris is me's Avatar
AKA: Pinecone
Re: pic: Team 2220's Swerve Drive Module
Be weary of the amount of chain wrap you have on that upper sprocket. Eyeballing it, doesn't look like a lot.
Unread 07-01-2011, 01:50
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
I would suggest #25 chain/sprockets and an AndyMark aluminum sprocket on the wheel. Much lighter and worked great for us in a similar module and reduction.
Unread 07-01-2011, 08:02
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
I have some concerns about the support of the module itself. It looks like you are using a single COTS "lazy susan" type bearing. My experience is that these sorts of bearings are great when it comes to thrust loads, but they can suffer devastating failures when subjected to lots of torque loads (imagine if your robot is being pushed sideways, or if it turns at a high speed - there's a lot of torque trying to pry your bearing open). Your pivot is located at the top of the module, so the distance between it and the floor acts as a lever arm and amplifies the torque the bearing will experience. We have used this type of bearing on turrets before, and twice we have experienced devastating failures after a big hit where the bearing cracked open.
If you want to get away with a single, high pivot point, I would point you to the www.team221.com Revolution swerve module design - if you read through their product descriptions, you will find the McMaster part # of the bearing they use for module support. Better yet, you can use multiple pivot points (one high and one low) to prevent excessive torquing at the top.
Unread 07-01-2011, 10:28
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
Jared is correct, the lazy susan bearing cannot handle the pivot function for a top mounted module like this. These bearings are relatively light sheet metal made for thrust load only. With the side loads and impacts you will see in FRC they will fail quickly (the sheet metal races that contain the ball bearings will fail and separate.)
Look at this recent thread: http://www.chiefdelphi.com/forums/sh...=swerve+module
It shows some mounting styles including our own. For modules with top support only, this support needs to be especially rigid and strong. Most module designs use lower support to avoid this difficulty. I notice you have a tall stem feature on top of the module. Could that be captured in a pair of bushings to form your pivot?
Unread 07-01-2011, 11:10
RoboLuigi RoboLuigi is offline
FRC #2220
RoboLuigi is an unknown quantity at this point
Chris is me: You concern is quite valid, we may have to change our gearing ratio in the future to fix this if it becomes an issue.
jspatz1: I definitely agree, we plan to switch to #25 chain and sprockets if/when we have a weight issue this season. We used #35 on our prototype to try to avoid chain stretching or breaking, and were going to try #25 next to see if we can reduce weight. Your team's success gives us more confidence that it will work well and remain durable throughout the season.
Jared341 & jspatz1: We had a similar concern with that bearing, in fact the students and the mentors spent an entire night discussing the issue. The main support for the module is the column on the top, which will be inserted through two bushings in the chassis much like you suggested, jspatz1. This will allow the module to pivot within these bushings, and the two points of contact will take most of our torque loads we may suffer from collisions or rapid direction changes. Our bearing therefore should only have to support thrust load. The only issue we have left is to find a more suitable bearing to take this thrust load.
Me and Jedward45 will try to post the other pictures of our swerve system ASAP so you can see our full design for yourself.
Unread 07-01-2011, 16:55
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
If you are capturing the top stem then it should all be good, as long as its connection to the module is strong. Here is the Mcmaster needle roller bearing we used for thrust load. Much smaller and lighter than the lazy susan. Just fit the ID closely and it requires no other guidance.
Unread 07-01-2011, 18:52
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
This is similar to what we did last year. A page with what we did.
http://wiki.team1640.com/index.php?t...VI_Drive_Train
Unread 07-01-2011, 19:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Unrelated specifically to the development of swerve, but
http://wiki.team1640.com/index.php?t..._annotated.jpg
is the best thing I've seen in months. Adding the McMaster standoffs to the wheel/sprocket interface is a fantastic idea that we will be stealing from you this year.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 08-01-2011, 02:00
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2007
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Wow really nice CAD work.
I would look into thrust bearings for the module.
Silverthin has a great selection:
http://www.silverthin.com/
Keep up the great work, posting different revisions up on CD is a great method.
Good enough is the enemy of anything great!
team 1671
Crab/Swerve Drive Module Attachment Point DinerKid Technical Discussion 5 20-04-2010 12:53
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
pic: Revolution Co-Axial Swerve Module - Team 221 LLC. ajlapp Extra Discussion 10 31-08-2009 15:28
pic: Team 1927's swerve module BlackBird11891 Extra Discussion 7 20-07-2009 09:19
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
