Go to Post After it took us weeks to machine sideplates for our 8WD, seeing their simple yet effective drivetrain was a huge "forehead slap" moment. - Chris is me [more]
Unread 08-01-2011, 12:32
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Drivetrain First Thoughts?
A drive system like the Omni or the Mecanum seems most fit for this year's game. Any first minute thought? The drive train I spend hours making yesterday came out to be useless for this...
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 08-01-2011, 12:36
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: Drivetrain First Thoughts?
The key to the small robot will be making something that's FAST! I don't know how putting the minibot higher on the pole will play out right now, but it seems interesting.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 08-01-2011, 12:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
My initial thought is KISS. No obstacles or special terrain means my initial reaction is the tried and true 6WD drop.
All subject to change as I go through game and strategy analysis of course.
Unread 08-01-2011, 12:56
lexxasaurus's Avatar
lexxasaurus lexxasaurus is offline
AKA: Lex
FRC #1727 (REX)
Team Role: Mechanical
lexxasaurus is an unknown quantity at this point
First thing I thought was fast, I think speed will be fairly important in this game. The faster you complete the objective the more you get to block the other alliance. My next thought is strength; I feel having a stronger drive train will give you an edge in blocking... then there is the being able to move any direction giving you an advantage in scoring because of maneuverability.
Drive train this year seems really dependent on what you team wants to do, not the field elements.
Unread 08-01-2011, 12:58
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Speed seems quite important. I too am inclined to go with 6WD.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 08-01-2011, 22:49
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
My first thought was
Tank drive will never work, since you have such an awful turning radius, unless your scoring system is seperate from the direction the robot is facing.
Next I thought Mecanum, since they can go sideways, and line up great for an elevator style scorer. But then I realized that mecanums are quite slow, so its quite a conondrum.
Could someone outline why 6WD would be good for this year?
Unread 08-01-2011, 22:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
6WD drop-center is doable with the KOP drive train straight out of the box, that's why it's so good for this year. IT WORKS right outta the box, and at a good, balanced speed too. It's good enough that veteran teams should already have the KOP drive train built by the end of today and can now work on their manipulators.
GitHub
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Well... go big or go home. 8wd swerve!
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 08-01-2011, 22:55
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
My team is most likely going to use the same mecanum drive as last year, as it'll allow for much easier self-alignment to the pegs (and therefore less error while placing the tubes). We'll just slide along the endline while everyone else will be trying to turn with their clunky 6WD
EDIT: @Grim Tuesday: D'you mean that mecanums are slow going sideways? I agree, but a crabwalk shouldn't last for more than a few feet to align to pegs, so it would be more advantageous to have the additional maneuverability -- sliding > turning
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 08-01-2011, 22:57
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
I was thinking more like 8 wheel omni... Like a giant octagon
LOL JK I got something cooler.
Unread 08-01-2011, 22:58
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
Rookie Year: 2007
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
Tank drive has 0 turn radius.
The reason why teams tend to go with 6WD Drop is because it shortens the effective wheelbase, reducing wheel "scrub". Basically it makes it so that the robot is able to turn without jumping around or stalling.
Mecanum drive can be just as fast as any other drive system, its all in the gearing.
blayde5's Avatar
blayde5 blayde5 is offline
AKA: Abhi
FRC #3504 (Girls of Steel)
blayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of lightblayde5 is a glorious beacon of light
Our team is heavily considering our first (successful) swerve drive this year. We figure that extra maneuverability while placing the tubes on the pegs will be extremely helpful. You can also lock the modules in place and run it as a tank drive so we have that option as well. We're hesitating a little because, although we built it during the offseason, we never have tested the electronics or controls (which people say is the harder part)
Otherwise, we'll go with a standard 6WD dropped center. It's simple, easy to make, and we'll be done with it in the first week.
Unread 08-01-2011, 23:03
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
I think a 4 wheel drive is sufficient. You don't need as much mobility as last year's game required. As long as you have an accurate racking mechanism, I don't think the drive matters as much.
Unread 08-01-2011, 23:11
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Check the 60" rule, make sure you know how accurate you can actually be.
  #15   Spotlight this post!
Unread 08-01-2011, 23:16
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
Rookie Year: 2000
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
Before you choose 6 wheel drop think of the slight rocking that occurs due to the middle wheels being lower. Another solution to this is omnis at the corners and having all wheels on the same plane eliminating rocking.
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
