Go to Post Playing fields outdoors in the snow and the only field faults were when you ran out of gas!...ahh the old days - ExTexan [more]
Unread 08-01-2011, 13:33
team1631's Avatar
team1631 team1631 is offline
FRC #1631 (Rockin Robots)
team1631 is an unknown quantity at this point
More than one minibot on robot
I could not find a limit on the number of minbots a robot can carry. I was thinking if the weight allowed could you put a backup minibot on the robot.
Unread 08-01-2011, 13:44
angelawence11's Avatar
angelawence11 angelawence11 is offline
FRC #0195 (Cyber Knights)
Team Role: CAD
angelawence11 is an unknown quantity at this point
Re: More than one minibot on robot
I think that would be fine, but you can only actually deploy one (i think)
Unread 08-01-2011, 13:49
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Definitely one for Q&A.
However: most references to the minibot are singular definite (the minibot), and you only get 10 seconds to deploy and run one. It's highly unlikely that you could deploy 2 in the same match. Common sense says that you will probably only want one on the robot (and at least one backup in the pit or on a different robot).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-01-2011, 13:56
RandAlThor RandAlThor is offline
FRC #0115
RandAlThor is an unknown quantity at this point
Maybe you could deploy a minibot on each of your alliance's posts if the other teams don't have minibots
Unread 08-01-2011, 14:05
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
In 10 seconds?
The time makes it very difficult to do. Deploy (you've already lined up), cross, line up, deploy, and assume defense slows you down during the crossing (because messing with a robot contacting a base is an automatic DQ). Can the second minibot make it up before the score won't be counted?
Question for Q&A: Given the many last-second minibot deployments, will a minibot that reaches the top after the buzzer still count? Personally, I'd go with "yes" (<G68>), up until 10 seconds (same rule). That makes the chance of 2 much more feasible, but then you have to worry about legality of 2 minibots.
Past teams:
Unread 08-01-2011, 14:11
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
I assume you can try shooting it all the way across the field and hope they hook on. Kinda like a Hail Mary pass. You just need to make your bot very accurate and very rugged.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 08-01-2011, 14:29
Captain Cox Captain Cox is offline
Safety Captain & Head of Machining
FRC #0004 (ELEMENT)
Captain Cox is an unknown quantity at this point
Cool Re: More than one minibot on robot
I like the optimism of your idea, but you have to deploy the robot at the base of the post.
Unread 08-01-2011, 17:20
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Not really at the base. The deployment line is 18 inches above the base of the large part of the tower, which means it is a total of 30 inches above the floor. For it to be optimal, you would deploy it as fast and as high as possible to it gets to the top the fastest.
Unread 08-01-2011, 17:49
ThePeracha's Avatar
ThePeracha ThePeracha is offline
FRC #1528
ThePeracha is an unknown quantity at this point
Are you positive? Where did you see that rule?
Unread 08-01-2011, 18:01
Waffles's Avatar
Waffles Waffles is offline
Ship it!
AKA: Crystal Vongnaphone
FRC #1511 (Rolling Thunder)
Team Role: Leadership
Rookie Year: 2007
Waffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant futureWaffles has a brilliant future
Send a message via AIM to Waffles Send a message via MSN to Waffles
It's not necessarily the BASE. When you "deploy":
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb)
DEPLOYMENT LINE – located on the POST, approximately 18 inches above the top surface of the BASE.
These are the Manual definitions.
I believe you have an 18" buffer zone on which you PLACE the minibot.
(Otherwise, correct me if I'm wrong)
Crystal Vongnaphone ... aka WAFFLES!
2010 Boston Regional Dean's List Finalist
FIRST Team 1511 Rolling Thunder
| Alumni | Leadership | Electrical | Media
Are you a Dean's list Finalist? Join our group!
Get the latest updates & important information on itsthedeanslist!
Unread 08-01-2011, 18:04
ThePeracha's Avatar
FRC #1528
Can it be thrown above the line?
Unread 08-01-2011, 18:06
Waffles's Avatar
Ship it!
Rookie Year: 2007
If you do it above the line, it must be during the End game period I think?
I'm not absolutely POSITIVE though.
Unread 08-01-2011, 18:09
goldenglove002 goldenglove002 is offline
AKA: Alex Epstein
FRC #1311 (Kell Robotics)
goldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the rough
This was one of my first thoughts when they were talking about sharing minibots. I definitely think it's possible to do, though very difficult.
After perusing through the manual it is definitely a question for Q&A.
Wording seems to imply the use of one bot, but never says anything definite against having two.
Unread 08-01-2011, 17:02
web_master_dpep's Avatar
web_master_dpep web_master_dpep is offline
"What you do, is who you are"
AKA: Dustin Pepper
FRC #0066 (Flyers)
Team Role: Webmaster
web_master_dpep is an unknown quantity at this point
Send a message via AIM to web_master_dpep Send a message via Yahoo to web_master_dpep
When looking at scoring it talks about a fourth bot on a pole being worth 10 points. That would imply, at least to me, that you could infact deploy two, if you had the time.
ŴΣß ΜăşťΣΓ đÞΣÞÞ
  #15   Spotlight this post!
Unread 08-01-2011, 17:09
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
That's the minibot that gets to the top of a pole fourth - lost the race.
(since 2004)
