Go to Post [this is rapidly turning into a 'how many engineers does it take....' contest :^) ] - KenWittlief [more]
Unread 08-01-2011, 14:06
kfgk14 kfgk14 is offline
FRC #1831
kfgk14 is an unknown quantity at this point
Minibot
Hypothetically, if one wanted to use a spring-loaded fulcrum to launch their minibot up the tower, would that be legal? Would the minibot then be considered a projectile? Does the minibot have to use a motor?
Would this be considered a safety hazard?
Could this (or a variation of this concept) be legal?
Unread 08-01-2011, 14:09
ShortBang's Avatar
ShortBang ShortBang is offline
Bring the Rain!
AKA: Ben
FRC #2199 (RoboLions)
ShortBang is a splendid one to beholdShortBang is a splendid one to beholdShortBang is a splendid one to beholdShortBang is a splendid one to beholdShortBang is a splendid one to beholdShortBang is a splendid one to beholdShortBang is a splendid one to beholdShortBang is a splendid one to behold
Re: Minibot
<G20> ROBOTS/HOSTBOTS may not contact their own TOWERS above the DEPLOYMENT LINE. Violation: PENALTY for contact. TOWER is disabled if MINIBOT is DEPLOYED above the DEPLOYMENT LINE.
In my interpretation that would amount to deploying it above the Deployment line.
Unread 08-01-2011, 14:56
Stephie Stephie is offline
FRC #1763
Stephie is an unknown quantity at this point
Re: Minibot
can we just shoot the mini robot up to the top of the pole or does it have to stay at the top for an amount of time? [i dont have the rules yet :/]
Unread 08-01-2011, 15:00
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Minibot
Those of us that downloaded the encrypted manual haven't been able to find an answer either. Q&A opens on Wednesday, by tradition.
However, I would advise against shooting one, due to reasons I've already discussed.
FYI: after you post, you can edit posts for a certain period of time. The edit button is at the bottom right corner of the post.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-01-2011, 15:09
FRC #1763
Re: Minibot
how tall is the pole?
Unread 08-01-2011, 15:16
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Minibot
From Section 2, about 122 inches up. And, before you ask, depending exactly where you hit it, you'll need about 2-4 N to trip it.
BTW, as Gary pointed out, there is no rule saying that the minibot must stay up. However, the first Update may change that, and if not, the Q&A will probably be asked. In other words, it may or may not stay that way.
Past teams:
Unread 08-01-2011, 15:23
FRC #1763
Re: Minibot
i have a couple of other questions, my team n i dont have the rules yet due to the rest of the world try'n to get the rules all @ the same timeP:
*can we use external power for the minibot?
*what is the pole made out of?
*can you take only one minibot into the arena?
*is there a floor line that leads to the pole so we can line up a minibot?
*can we control the minibot via remote once released from the large robot?
if u can answer these questions for me that would b AWSOME!!!!
Unread 08-01-2011, 15:33
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
Re: Minibot
We were debating this, and we raised this question; however, we came to the conclusion that if anything were left at the bottom at all, it would definitely exceed the 12" dimensions on the minibot. Good luck!
EDIT: Just found this in the rules:
<R101> If a MINIBOT is rejected by inspectors due to a safety issue or concern related to the team’s method of storing energy, the concerned items must be disabled or removed from the MINIBOT before it can compete in a MATCH. The team bears the burden of proof that such a rejection is not valid. Teams should be prepared to provide justifiable test data or calculations during inspection to support their design.
Storing energy in the form of pneumatic pressure or a spring to launch it is probably considered, as someone said before, a safety violation
Last edited by Superllama12 : 08-01-2011 at 15:38. Reason: Discovered another rule
Unread 08-01-2011, 15:43
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Minibot
This is why the encrypted manual is released. It's so that you download it ahead of time and avoid the rush. Guess a lot of people missed that memo this year.
The answers can be found in Game Section 4, Game Section 2, unknown, Game Section 2, and Game Section 3.
In order, No attachment, but there is a battery allowed, Steel, unknown, Yes, Not if you want to get points, and there is a risk of hurting your entire alliance (Short version: If you don't get to the top, the first pole on your alliance is not counted)
Past teams:
Unread 08-01-2011, 15:50
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: Minibot
I think the biggest problem with spring loaded minibots are that there are no springs in the FTC KOP.
Unread 08-01-2011, 15:56
Wombaticus
Exclamation Re: Minibot
Sorry for having so many posts, but I just found a rule that PROHIBITS ANY LAUNCHING MECHANISM WITH STORED ENERGY INCLUDING PNEUMATICS, SPRINGS, AND OTHERS NOT MENTIONED!!!
Unread 08-01-2011, 16:07
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Minibot
Really? Then why are there rules about stored energy devices? (Blue box on <R01>, <R90>)
You should quote or cite any rules that support any conclusions you make.
(since 2004)
Unread 08-01-2011, 16:08
AKA: Simon Bohn
Rookie Year: 2010
Re: Minibot
I don't see that rule.
The only rules that mention springs, explicitly allow them, unless deemed unsafe.
<R01> Energy used by FRC ROBOTS, (i.e., stored at the start of a MATCH), shall come only from
the following sources:
A. Electrical energy derived from the onboard 12V battery (see Rule <R34> for specifications
and further details).
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts.
Teams must be very careful when incorporating springs or other items to store
energy on their ROBOT by means of part or material deformation. A ROBOT may be
rejected at inspection if, in the judgment of the inspector, such items are unsafe.
Unread 08-01-2011, 16:32
De_Code_Master's Avatar
De_Code_Master De_Code_Master is offline
Jane of all (robot) trades
AKA: Helena
FRC #1758 (Technomancers)
Team Role: Leadership
Rookie Year: 2007
De_Code_Master is an unknown quantity at this point
Send a message via AIM to De_Code_Master
Re: Minibot
In the introduction section of the manual, the definition of DEPLOYMENT is :
"DEPLOYMENT-- the act of positioning a MINIBOT on the TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME."
This seems to say that once it enters the platform, the minibot counts as being deployed if it is "positioned" or attached to the tower somehow. So if you interpret it that way, it means you can't shoot a minibot at the sensor, because it wouldn't get positioned on the tower. Just my $0.02. Someone on my team also suggested popping a little minibot out at the sensor, like a tennis ball machine, and this was my rebuttal.
1758: Metal and Magic
We deliver!
Peachtree 2010 quarterfinalists: Thank you, 1746 and 1261!
Palmetto 2010 semifinalists: Thank you, 49 and 945!
  #15   Spotlight this post!
Unread 08-01-2011, 18:46
ThePeracha's Avatar
ThePeracha ThePeracha is offline
FRC #1528
ThePeracha is an unknown quantity at this point
Re: Minibot
If it passes the whole pole up and just merely touches the sensor at the top, is that considered deployment? If it isn't, then won't we able to just launch at the sensor, considering they can withstand the force?
