Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 08-01-2011, 15:10
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Minibot controller
I'm confused about how the minibot is supposed to be controlled. Are we required to have a controller on the minibot or is a custom circuit good enough? What is the proper way to activate the minibot? Do safeties need to be in place to shut down the minibot after the match ends?
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 08-01-2011, 15:15
TomH's Avatar
TomH TomH is offline
FRC #0087
TomH has a spectacular aura aboutTomH has a spectacular aura aboutTomH has a spectacular aura about
Re: Minibot controller
Minibots are autonomously controlled and must remain in autonomous the entire time they are deployed.
Unread 08-01-2011, 15:16
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Check out section R92 for details on what is and isn't allowed on the minibot.
If you want a controller, you must use the NXT. I believe that a simple custom circuit (switch, battery, motor) would also be legal.
There is no "proper" way to activate the minibot. This is all in your specific implementation.
As for shut down safeties- I would recommend it though because you will be penalized if you damage the field or any of the judges perceive you as a safety hazard.
Team 2052- Knightkrawler
Mentor and volunteer
