Go to Post Tell them your newfound passion for FIRST as a program, and let them know all you're doing is getting more involved to broaden your FIRST horizon - Dorienne [more]
Unread 08-01-2011, 19:07
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
Visibility of field from drivers station
For those that went to the kickoff, did you look at the field from the drivers station, how much could you see with tubes blocking your view?
2005 - GTR WFFA
2006 - Waterloo Regional Champions with 1114 and 1503
2010 - Waterloo Rookie inspiration and Highest Rookie Seed, #2 Alliance Captain, Semi-finalists.
2011 - Waterloo Finalist thanks 1310 and 610
2014 - imagery and rookie allstar award gtr west
2014 - rookie inspiration and winners with 188 and 610 north bay
Unread 08-01-2011, 19:23
unionylibertad's Avatar
unionylibertad unionylibertad is offline
unionylibertad is an unknown quantity at this point
Re: Visibility of field from drivers station
i dont think it would matter that much. you can have the webcam, after all.
Unread 08-01-2011, 19:30
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Framerate on the driver's station from the camera can be pretty poor. It'll matter a lot.
Even in 2007, at least one team started out by placing tubes on their opponent's side of the rack. You get decent vision, they get obstacles, and that's with the tubes 20 feet away!
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-01-2011, 19:33
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
This is really important anyone have any response? How clear is the glass and can the whole rack be seen from the driverstation? If you know my my goal, you can infer what I am going to do.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 08-01-2011, 19:35
alectronic alectronic is offline
no team (Volunteer)
Rookie Year: 2007
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Especially with the middle level being so "accessible" of a height for many of the robots, and that is where many of the visibility problems will likely occur. While the webcam is nice, I think this is where the analyst will be a bigger part.
InItToWinIt's Avatar
InItToWinIt InItToWinIt is offline
FRC #2871 (Beantown Bots)
Team Role: Driver
Rookie Year: 2010
InItToWinIt is an unknown quantity at this point
if you don't use your camera you will lose your visibility almost completely by the end of the match.
Unread 08-01-2011, 19:37
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Here is a photo from the driver station. I wanted to get more but I had to get out of there. It wasn't too bad, once the row had 6 tubes all across it, seeing was an issue. It will come down to strategy as the middle will probably get scored on last.
http://www.flickr.com/photos/58037296@N02/5336976065/
You can also check out more pictures on my stream as well from Manchester.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
i know, it's a bad idea to only look at the webcam image, but poor visability can be compensated by looking at the screen, no?
Unread 08-01-2011, 19:39
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Screen's blocked too, if there's anything on the high rows. Pretty much, visibility is best and score is worst when bottom row is filled, and visibility is worse but score is better when the upper rows are filled. Completely aside from the fact that camera operators just love stationary robots that aren't your fast-moving one.
Past teams:
Unread 08-01-2011, 19:40
Vince lau's Avatar
FRC #4914
Thanks for the picture Brendan
2005 - GTR WFFA
Unread 08-01-2011, 19:43
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
I got a solution for that sir. An axillary camera. No rules about that. A camera located next to the driver station.
Unread 08-01-2011, 19:54
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Better solution: score on middle row last.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 08-01-2011, 19:56
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Oh, you mean not on the shelf? You mean in violation of <R77>?
And if it's wireless communication, throw in <R79> as well, and I might add <T25> into the mix.
In short, if it isn't part of the operator console, forget about it legally, and if it's on the console, it's got the same disadvantage as human eyes.
Aside from the camera operators loving flipped robots instead of the ones that the teams want to see...
Past teams:
Unread 08-01-2011, 19:58
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
You sure about that? Look at <T25>.
(since 2004)
  #15   Spotlight this post!
Unread 08-01-2011, 20:00
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Can anyone post the password again? I can't seem to open it up....
