Go to Post award or no award, you're still smelly. :D - AndrewMorrison [more]
Unread 08-01-2011, 19:09
Peter Johnson Peter Johnson is offline
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Laptop on 2011 robot
Per the game rules, it looks like they went to a lot of effort to specifically make it legal to use a COTS laptop on a robot:
<R34> Batteries integral to and part of a COTS computing device are also permitted (i.e. laptop batteries), provided they’re only used to power the COTS computing device.
<R45> F. drive motors or fans that are part of a speed controller or COTS computing device.
<R50> B. Ethernet-connected COTS devices or custom circuits may connect to either cRIO-FRC Ethernet port; however, these devices may not transmit or receive UDP packets using ports 1100-1200 except for ports 1130 and 1140.
Anyone have any clever uses for a laptop on the robot? (assuming you want to spend the weight...)
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
