Re: FAQ for Q&A
Remember, we aren't Q&A, but I can shed some light: autonomous is not controlled by the humans. I would also suspect that contact with the minibot in the deployment area is fine, as long as it didn't continue after the deployment line, but I can't be totally certain. See #8 in the list.
The hostbot will not be able to communicate with the minibot, BTW, due to the minibot size and lack of communication ability. |
Re: FAQ for Q&A
Re: FAQ for Q&A
Just a quick clarification on <G19> (under my interpretation):
1. First of all DEPLOYMENT (as defined in the introduction) is: Quote:
Autonomous basically means it can't have external commands (I believe - it definitely cannot have human control). Whether or not it can communicate with your hostbot is solved by the fact that there is no way of doing so with the allowed parts and also that there is little reason to do so - if the minibot is running code off the hostbot, it might as well run its own code. Hope this clears that up. Also, as a general thing, people sometimes overlook the glossary in the introduction when reading the rules. Any word in the rules that is all in capitals is in the glossary. Check there first. |
Re: FAQ for Q&A
What are the limitations on pnuematics this year??? The rules (Section 4.3.11) say that the KOP tank but it never says if we can or cannot have more tanks. Also a similar question about cylinders. Can we have more than the three Bimba KOP cylinders or not??
Re: FAQ for Q&A
I do not have an answer to your question about the cylinders. |
Re: FAQ for Q&A
Re: FAQ for Q&A
That is what that question is asking. Remember, minibots have zero connection to the field controller, so they aren't shut off when the robots are. |
Re: FAQ for Q&A
for example, the first one is: A 16.875" [428.6 mm] segment on top 1 B 14.125" [358.8 mm] pegs 3 C 35.25" [895.4 mm] between the two pairs of pegs 2 D 37.375" [949.3 mm] lower segment to the floor 1 From this you can get very close to the heights involved. However, the dimensions of the T-fittings used to make the assembly will affect the heights slightly. That is, the vertical segments are not strictly additive. Not a plumbing nightmare at all. Last edited by Bill_B : 09-01-2011 at 19:53. |
Re: FAQ for Q&A
#10
Re: FAQ for Q&A
If the GDC comes out and says that the minibots have to pass FTC inspection, the uproar over requiring the FTC motors for vertical motion will be as nothing compared to the ensuing "virtual riots". FYI: FTC inspection != Minibot inspection. Minibot inspection will check for size, weight, and legal parts. I'm sure FTC inspection is a bit more rigorous. |
#11
Re: FAQ for Q&A
Re: FAQ for Q&A
1) Minibots at the top of the pole: Do they have to stay there until after the match, or can they slide down during/after the match under their own power or via gravity to make retrieval easier?
2) Are you allowed to move your own tubes, other than ubertubes, around after they are in scoring position? 3) If a minibot is moving upwards at the end of a match, does it still get the 10 seconds to finish for points? 4) Assuming an NXT is used, are the internal batteries allowed power sources? 5) Wiring rules/conventions/schematics for Minibot--where are they, if there are any? 6) What methods are acceptable for removing the Minibot from the post? For example, could it drive itself down autonomously? Could someone bring a long pole out and activate something on the robot to make it come down? 7) For determination of "above the line" during deployment, is the top of the Minibot supposed to be below the line, or just the hostbot device? 8) Pneumatics rules are unclear: How many and what type of a) storage tanks, b) cylinders, and c) other pneumatic actuators are allowed to be used on a robot? 9) Can a tube intentionally be placed over the minibot tower? 10) Who records the coopertition points? How does anyone know if a scoring minibot has been loaned by another team? 11) Does <R14> have any exemptions for fastener heads? 12) What are the exceptions for objects/manipulators passing through the Bumper Zone?: a) Is it legal for an arm to enter the bumper zone and not be protected by bumpers? b) Assuming (a) is legal, what if the object entering the bumper zone is not intended to manipulate a game piece (ex. wheels to support a larger structure which deploys from the starting configuration at some point during the match)? |
#13
Re: FAQ for Q&A
Re: FAQ for Q&A
#1 has been answered. Just hit the target, then prepare to retrieve however you want to do it.
The GDC has only answered 3 questions at this point in time, so I'm not surprised there aren't more. |
#15
Re: FAQ for Q&A
I'm thinking there will be a whole bunch of answers coming out late tonight (Friday) after Team Update #2 - and most of them will say, "No, please see Team Update #2".
Team Update #1 was published before Q&A was opened, and it changed some very basic parts of the game - clarifying what the GDC intended and what thought they had said in the first place. Now they have some questions from the teams, and will answer them and make rules updates as needed. These updates will be minor clarifications of existing rules - but they will be major for teams that made assumptions contrary to the GDC's asssumptions. Last edited by GaryVoshol : 14-01-2011 at 11:11. |
