Go to Post 256:1 gear reductions provide surprisingly little torque once the gears have failed. - Kevin Sevcik [more]
Unread 08-01-2011, 19:46
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
Rookie Year: 2010
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
2011 Classmate Image Windows Verification?
After 1178 got our KOP, we went back and reimaged the Classmate. Once that was over, we found out that the classmate did not have any programming sources (aside from National Instruments Vision Assistant). But our main problem was that every time we switch users we get a message saying to input a windows to key to verify our software was genuine. Has anybody else had this problem, and if so, does anybody know what we're supposed to do?
Note: You cannot tell the difference between "OK Go" and "OK No" when there 2 walls between you and the robot. At that point, the only thing between injury and safety for the mechanical guys is their ninja skills.
Unread 08-01-2011, 20:19
Baconfly Baconfly is offline
AKA: Tylor
FRC #3330
Rookie Year: 2010
Baconfly is an unknown quantity at this point
Re: 2011 Classmate Image Windows Verification?
If you have a working internet connection, it should have successfully activated once connected. Also, I'm assuming you have a 2010 classmate, are you experiencing any low disk space errors? I reimaged my classmate and now i have 0 bytes left.
-UPDATE
Turns out Windows was excessively increasing the size of the page file. Now have about 600mb free on the 16gb ssd, which is manageable, however not enough to install Labview, which is a good enough reason to switch to a better laptop for programming.
I'm still trying to figure out how much of this is User-error, if it is at all.
Unread 08-01-2011, 20:55
ashleyh ashleyh is offline
Ashley H.
FRC #0540 (Talon 540)
ashleyh is an unknown quantity at this point
We reimaged our classmate as well--no programming software on ours, either. We're planning on copying the installation disc files onto a flashdrive and installing it that way, or installing LabVIEW to a flashdrive and running it off that. When you were done with the reimage and booted the classmate normally, did it ask you to connect to the internet to verify your activation or something like that? Ours did, and it seems to be working without an activation key.
Unread 08-01-2011, 21:05
AKA: Tylor
FRC #3330
Rookie Year: 2010
I didn't think about running off of the flash drive....
Unread 08-01-2011, 21:13
Ashley H.
Neither did I! Kudos to one of the other programmers for that one. Good luck!
Unread 08-01-2011, 21:29
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
Mentor
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
It shouldn't really be asking for the key. Microsoft's activation server seems to be unreachable anyway, so it's not like it matters.
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
Unread 08-01-2011, 21:35
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Make sure you have a decently fast flash drive for installing Labview onto otherwise you may have a lot of crashes or "not responding" scenarios due to the limited bandwidth.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 08-01-2011, 22:59
AKA: Tylor
FRC #3330
Rookie Year: 2010
Will do, waiting on a drive so i dont have to use my personal.
